Holden WM dies if started when warm and don't give it gas
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Caprice LTZ, Jul 29, 2019.
  1. Caprice LTZ
    Caprice LTZ New Member
    Saudi Arabia
    2007 Holden Caprice
    Hello everyone, I own a 2007 chevy caprice LTZ (middle east version) V6 has about 260,000 km on it. The issue I am having is the car will die immediately if I start it after it has warmed up. It won't do this if I start it early in the morning or if it has been parked for a while. There is no check engine light. what could the issue be?
  2. syked
    syked Donating Member
    2011 WM Caprice
    I'm thinking it's a fuel delivery issue. Maybe the pump is on it's way out causing it to overheat then shuts off.
    Does it do it regardless of how much fuel is in the car?
  3. Caprice LTZ
    Saudi Arabia
    2007 Holden Caprice
    It does it regardless of how much fuel it has. I tested the pump and it holds pressure fine. Though sometimes when I start it cold, it feels like it's misfiring and few seconds later it runs fine. Not check engine light
  4. lazyc
    lazyc Member
    Eagle Farm
    VE SSV 6.0 M6
    Check the purge solenoid.
    It doesn't pop an error, if you can start with a touch of the loud pedal, it's probably that.
    The extra vapor from the tank is changing the mixture far to rich.
    My 2 cents.
  5. Caprice LTZ
    Saudi Arabia
    2007 Holden Caprice
    I'll try and test it. I can hear it clicking every few moments but I assume this doesn't mean it's functioning correctly
  6. tml678
    tml678 Well-Known Member
    HSV30 Senator (w/end), '00 Magna, '17 Carnival
    Pull the choke out...
    Caprice LTZ likes this.
  7. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    hahahahahahahahahahahahahah
  8. Caprice LTZ
    Saudi Arabia
    2007 Holden Caprice
    Well, the way the car is acting it might as well have a choke
    Lex likes this.
  9. syked
    2011 WM Caprice
    Remove it and blow into it. If you can blow into it both ways without restriction there is a problem with it.
    Should not be able to blow into it unrestricted.
  10. VFSV6FORME
    VFSV6FORME Well-Known Member
    VF SV6 STORM Series 1, VE Anniversity V6 Series 1
    OK when Cold, Stalls on starting when hot but what happens when it stalls for the fist time and you restart it again within 30 seconds to 1 minutes without no help from you foot. Does it start by itself and keep running?
