Homemade intake
Discussion in 'VE Holden Commodore (2006 - 2013)' started by monkeyboy, Aug 2, 2011.
  1. monkeyboy
    monkeyboy New Member
    2010 VE SV6 SIDI
    I made this a few days ago and fitted the thing today. It aint pretty, but it gets rid of that silly plenum with all its convoluted chambers and noise suppressing twists and turns. Cost me about 50 bucks, including the heatproof paint.
    It's 90mm PVC rainwater pipe...completely airtight, the breather hose is connected and the thing sucks in air like crazy. It all fits like a glove and is as solid as a rock.
    I'm happy with it. And seeing as I spend my time in the car driving it rather than gazing like a schoolgirl at the engine bay, the faact that it is a bit lumpy doesn't bother me a bit. :)
  2. Critical Jim
    Critical Jim Member
    Adelaide Hill's
    VE Calais, VL SL
    Neat ,so Mcguyver drives a Holden.
    Nicely done.
  3. bogan_vk
    bogan_vk New Member
    australia
    commodore
    looks good ,ive also got pvc rainwater pipe as my intake pipe on the vk been using the same pipe for years with no problems.
  4. Lumps of cheese
    Lumps of cheese welcome to the machine
    Warrnambool
    83 vh sle, 4x4 hilux, 03 monaro, 07 nightrain
  5. walesy
    walesy Aint no family cruiser!!!
    Perth SOR
    Cherry Black WH II Caprice, VS exec wagon
    its always good to make something yourself, who cares if it isnt the best looking intake (still looks good IMO) i made one when i was younger that went down behind the front bar for a home made CAI
  6. HussySV6
    HussySV6 New Member
    VW GOLF GTD
    Looks good champ. Did you change the filter aswell or left the stock one ?
  7. UFO
    UFO I Believe
    MY10 VE International Sportwagon SIDI 3L
    i reckon that looks better than some of the 'custom' crap i've seen for sale.... so well done :thumbsup:.
    and as long as it's functional, who really cares what it looks like anyway.
    i've always wondered however, why intake pipes arent wrapped in thermal tape like they do for extractors to keep the exhaust gas as hot as possible for as long as possible? same principle would apply for the intake... try and keep the air as cold as possible. insulating it from the high underbonnet temps could only benefit fuel economy and power gained, by keeping the air as cold (dense) as possible. as such, since you are doing your own mods, have you considered wrapping that sucker up? ok, its not going to look pretty.... but who cares, if what you are trying to achieve is meaningful modifications. alternatively, those rubber gromets could act as mounting points for some sort of heat shielding.... creating an air dam between the two surfaces (kind of like double glazed windows), so an outer skin over the top of your current piping could help even more to insulate the intake air.
  8. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    hey mate looks good, but there is a reason why the factory duct have a ribed surface.
    better air/fuel burning in the combustion chamber.
  9. some_guy
    some_guy Donating Member
    brisvagus
    VR SII Exec.
    That Makes...... No Sense.
  10. Jesterarts
    2010 Nissan X-Trail ST-L
    Ribbed for the cars pleasure?
    Yes, there is a reason but no, it's not what you said.
    And having a non-ribbed pipe improves airflow as the ribbing that is factory has a negative effect of the airflow.
  11. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    what makes no sense?
    You need turbulence thats why you see air ducts that are turbulent after the maf.
  12. Pickle'
    Pickle' Donating Member
    Sydney, NSW.
    VE Omega
    That looks neat as on the car, well done.
  13. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Do you believe hiclones work? Same principle.... The reason a lot of companies use the ribbed pipe is for 2 reasons. 1 it helps with routing being flexible and 2 due to the turbulence caused by the ripples it actually helps to quieten down the intake noise.
  14. some_guy
    brisvagus
    VR SII Exec.
    Now that. Makes more sense. Hence when a smoother piped CAI is installed = increased induction noise.
  15. General Xander
    General Xander Epic
    Bacchus Marsh VIC
    '96 VS Executive 3.8L
    as said above, the convoluting it to let the engine move under load with out pulling the pipe out thats why i used a stretchyer piece of silicone hose on one joint so the intake flex with the moters movement. with out it it just kept getting pulled apart. and those 'ducts' after the maf are to straiten out the air flow, to reduce turbulence. mine is very slightly less resposive since the 'ducts' were blown out by a particularly large gas backfire. the 'duct' actually punched a hole right through the front of my air box in that particular one lol. damn lpg
  16. Jesterarts
    lol...
    So apparently you know something more that that all those peolpe who do the GTS mafpipe upgrade and various other aftermarket part suppliers who set smooth pipes as upgrades.
  17. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    Maybe you guys can go explain to the tafe teachers your theory.
    Done my trade and have been a tradesman for 10 years now.
    This theory is valid on N/A
    Ask your self this question why are golf balls not all smoothed they have all little holes all over them.
    A golf ball that will be smooth all over wont travel as far a as the turbulent ball.
    Thats all i have to say.
  18. some_guy
    brisvagus
    VR SII Exec.
    Tell me then, Being in the industry myself, why a planes wings aren't ribbed.
  19. Jesterarts
    Hmmm... i was going to ask myself that question, but then remembered I'm not retarded and I successfully finished high school.
    My car doesn't play golf, nor an I intending on having it suck up gold balls.
    FYI, yes, gold balls have dimples to cause turbulance around them and therefore fly further but unfortunately the same theory cannot be applied to intakes.
    Completely different airflow principals apply.
    I think I've said this in the past, just because you have been doing something doesn't mean you're good at it.
    In the case of intakes, you want the pipes to be as smooth as possible to reduce turbulence.
    Either way, it has absolutely nothing to do with air/fuel in the combustion chamber.
    Turbulence is needed AFTER the fuel has been introduced and last I checked, fuel is not introduced into the intake pipe.
    As wraith said, the reason the factory pipe is ribbed is because flexible, because it quietens the intake and one addition form me is that it prevents engine vibration causing stresses on intake components unnecessarily .
  20. Jesterarts
    Planes don't get no satisfaction.
