Hooking Tacho Up!!! Help Me!!!
SiLeNt-SoN
2000 WH Statesman
2000 model WH statesman
Hey
just got my tacho, was wondering how to hook it up, it is a 1984 commy executive, i nned to things like where i wire it up to? and what wires?
any ideas and help welcome lol
Thanks!!!:thumbsup:
ENV5
VS Exec, VC SL/E V8, 2x Lada Nivas
red = positive
black = negative
green = negitive coil
white = parker wire
SiLeNt-SoN
2000 WH Statesman
Hey,
thats about what i needed to know, but were are these wires placed? in a black coil of wires under the hood? or like under the steering wheel? or in the dash somewhere?????
and things like, red=positive, but what colour is the positive wire?
im hopeless at this! lol
thanks
ENV5
lol just run the red wire to the positive battery terminal
run the black wire to a bit of metal under the dash
with the green wire run it to the coil you will see a little - mark on one of the 2 terminals
now your parker wire is usually a dark purple or violet colour best bet would be to get a test light and try and find it under your dash if you think you found it turn the parkers on and off and if your test light goes on and off you know thats the one but best place to look for it would be in the light switch wire loom
DANNY8
Yo Coooornflake!
34
Port Pirie, South Australia
www.kerrbrosracing.com
VK WAGZ 5.0L, GQ Patrol TD42
lol I never thought of that, for mine I just ran the wire straight to the coil.....will remember next time. ;)
atrail308
RIP King of the Mountain
southside adelaide
V8 VH SL/E 308
you're better off hooking the power wire (red) to accesories, ie. cigar lighter, clock, stereo, etc... As for the light, an idea would also be cigar lighter, clock as it then the brightness of the tacho light can also be adjusted/dimmed...
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
This is just a tip#
When using the 12v accessory in the fuse box, make sure your key isnt tunred to far fwd, i've noticed with mine being 1/2mm to far fwd wont activate the 12v access.
So if you think your connects have an outstanding stable hold, and nothing isn't happening.. just make sure your key isnt that extra bit fwd. :D
SiLeNt-SoN
2000 WH Statesman
i have:
red wire - Battery
Black wire - earthed
green wire - coil
white wire - lights
now i have hooked these up this way, but it is not working?
any ideas welcome please!
thanks
VKStevo
VP Exec
hey mate...similar problem, same person 2 help out, good on ya ENV5
what part isnt working? the lights or the tacho itself? or everything?
atrail308
southside adelaide
V8 VH SL/E 308
did you connect the green wire to the negative terminal on the coil???
