Hey Guys Just reading through:
-Got told other day by a guy at Dick Smith Electronics, that if running to amps, they need to be FUSED (I.E Distributation block), within like a certain amount of length I.E 1 Metre.
Otherwise it is illigal, but im unsure on that ay.
Anyway, as guys above have said you will need to Run distributation block, and for negitive best to run that off the BATTERY aswell, if earthing it in boot (Of any metal, like most of usdo) can get some certain interferiance. If earthed of the battery, you will eliminate any of this interfirance.
Also you should make sure that you have the power wire running down the side with main power in the car, if not when running speakers will pick up some interferiance, but you wont if running a sub, because lower frequencies. So Check they are right, other wise have the hassle of re-wireing it.
Cheers bro
