Horn Issue
rippen50
Braaap
Camden
VE SS-Z UTE MY12.5
Yo all... my horn has been playing up for the last 6 months that being it not working when i press it i checked the fuse it was blown.. so i went and got 4 new fuses and every time i put one in and pressed the horn it would blow the fuse!!
what do i do? cheers
rippen50
Braaap
Camden
VE SS-Z UTE MY12.5
the horn's not the problem it a switch or the electrics or something i just wanna no if anyone knows what to do
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
unplug the horn & see if the fuse still blows, you should find it doesnt, then get a new horn
rippen50
Braaap
Camden
VE SS-Z UTE MY12.5
in saying that how to i disconnect the horn? do u mean from the actual horn or from the steering wheel
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
No, it's connected with two wires, behind the bumper on the driver's side. You have to get down on the deck to see it, below the headlight. Just pull one wire from the horn and try the horn button. If the fuse doesn;t blow, the horn is the culprit. If the fuse still blows, check the relay. Swap it over with a similar relay from the fuse box. I think the horn relay is located in the engine bay in front of the driver's side suspension tower. It's under a clip-on cover which will show you which relay to check. (Fuse and relay lay-out moulded on underside of cover)
You can see from the labelling on top of the relay which ones are the same to try the swap.
sp001in
vyma100
39
QLD
VY ute
last post = solution.
get air horns !!!!!! I have got them and they are ****en grouse
rippen50
Braaap
Camden
VE SS-Z UTE MY12.5
i am going to get a air horn soon if this is the case i will be getting one... Thanks
ucrvme
[UCRVME]
Melbourne, Victoria
2003 Holden VY Berlina
Hey Dude, I wanted to get air horns in my VY Berlina i called this auto elec an he said its not possible because my bay is full up - im curious what car do you have and how many horns do you have?
