Horn just stopped?
Discussion in 'VY Holden Commodore (2002 - 2004)' started by rippen50, Jan 6, 2009.
  1. rippen50
    rippen50 Braaap
    Camden
    VE SS-Z UTE MY12.5
    As it says in my VY exec my horn just stopped i held it in for about 10 seconds than went to press it again and it didnt work????? any help cheers
  2. Jbird
    Jbird New Member
    Wheelers Hill
    VY monaro
    check if ur alarm works, open ur car up with ur keys manually
  3. hakhawk
    checked the fuse?
  4. rippen50
    rippen50 Braaap
    Camden
    VE SS-Z UTE MY12.5
    Jbird: some how the alarm does work it went off today...
    hakhawk: i did i changed it and still not working... i might double check thought just to be sure
  5. alien
    alien New Member
    Tullamarine, Vic
    03 VY Supercharged 3.8L
    If your alarm works then it sounds like the "switch" is the problem. Time to take off your horn and check that it's grounded and all wires are plugged in! And the horn makes contact! xD
  6. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    My VP has a seperate horn for the alarm, so i'd assume they havn't changed their setup, so it doesn't sound like that.
    If could be the plug that earths to the steering column.
    What or who were you beeping at for 10 seconds?
  7. rippen50
    rippen50 Braaap
    Camden
    VE SS-Z UTE MY12.5
    I got cut off and almost crashed so yeah.... i won't be doing that again =[
  8. alien
    alien New Member
    Tullamarine, Vic
    I'm fairly sure the VY's have 2 horns but are both linked by the 1 relay which the horn and the BCM have access to using [according to the wiring diagrams]. If the Alarm works and the Horn doesn't then it's a fault with the Horn, if both dont work it could be the relay or both horns!
  9. Jbird
    Jbird New Member
    Wheelers Hill
    VY monaro
    u need a new horn, easy fix same thing happend to mine, it shorted from the saftey sticker behind airbag and blew the horn, it by passes the fuses thats why its dead
  10. rippen50
    rippen50 Braaap
    Camden
    VE SS-Z UTE MY12.5
    so u reckon just wack the air horn in now?
