Horn??
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by gupatrol, Dec 4, 2007.
  1. gupatrol
    gupatrol New Member
    Perth WA.
    R33 Skyline, VX 5sp.
    G'day,
    I have a 'sports' steering wheel (SAAS) on my VR. Everytime I turn the blood wheel, ie going around a roundabout the bloody horn goes. People just look at me like im some kind of road rage nutcase :bang:
    Where is the horn under the bonnet? I'm just gonna cut the bloody cable??
    Any help would be great.
    Cheers :thumbsup:
  2. dufus
    dufus Donating Member
    rickshaw
    Im fairly sure that it is on the right hand side of the car behind the front bumper.
  3. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    why dont you stop being lazy and just fix your horn?
    Its most likley that your horn ring is fouling on the wheel or something very similar.
    Horns are very important.
    There mounted under the front bumper drivers side below the headlights if you must dissconnect it.
    aZk.
  4. VLDavo
    VLDavo New Member
    lc torana. vn v8. ke30.mazda 1300.
    mahahah i had an old vl that did that id say one of the wires isnt tucked in enough and its grounding itself when u turn..... just pull it off and make sure everything is where its ment to be its only a 30 minute job
  5. gupatrol
    gupatrol New Member
    Perth WA.
    replaced the ring, still does it. checked the wiring, still does it.
    Might be down the steering column under the dash somwhere, im not about to go and pull it apart during the week when I have a heap of other sh!t to do and work in a few hours.
    Just pulled the fuse and relay out for now.
  6. kopper69
    kopper69 New Member
    VRII Acclaim
    Horn is easy enough to get to, but you need to determine if its the wiring at the horn or the wiring in the steering wheel/column. I would grab the horn and just see if you can move it, maybe its just sitting a bit loose and the connector is grounding.
  7. Summer-Sickness
    Summer-Sickness 2005 VZ EXEC
    Rockingham, Perth
    05 VZ Executive
    you said you replaced the ring... in my boss kit the ring is fixed to the boss kit... if your ring can move around by itself thats probably whats causing your problem, but then again your boss kit might be a different story.
    had this problem and mine was because the horn ring became unglued and it kept fouling and jamming in the steering column... the horn going off is bad enough but mine jammed my steering also...
    anyways back to your problem is... does your horn ring move freely? coz i dont think its meant to, other members may be to tell you whether this is correct for your particular boss kit.
