hose came lose - now big problem filling up coolant - always boiling over
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Schwuppes, Jul 23, 2012.
  1. Schwuppes
    Schwuppes New Member
    WA
    VT Calais L67 (conversion)
    Hi people
    After finishing my L67 conversion we had it all up and running sweet, but then a hose from the heater tap came lose and sprayed coolant everywhere. I immediately switched the engine off (within like 5 seconds).
    Now when I try topping up the coolant it just boils and sputters out of the radiator cap all the time, and after a while the engine makes a strange noise, maybe because its overheating? (pinging?) it doesnt even accept any coolant, it all just boils over, and gets worse the longer the engine runs
    Im hoping nothing has been damaged :( after the hose came lose I waited an hour until the engine was reasonably cool again... do I have to wait longer until its stone cold?
    appreciate any advice
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Did you bleed the system, there might be air in it?
  3. Beav
    Beav New Member
    Emerald
    93 vr commodore
    New radiator cap? Pressure test
  4. micky vn man
    micky vn man New Member
    gladstone
    vn v6 calias
    theres air in there by the sounds of it ...new radiator cap and coolant and bleed the system should do the trick.o and new thermostat..
  5. Schwuppes
    WA
    ok cheers guys....
    il try to use the thermostat off my old engine thats still laying around here.
    Another thing I noticed was when I turn the key in the ignition, just to bring up the electrics/dashlights etc (not starting the engine) i can here a continuous clicking sound coming from the drivers side under the car somewhere. the clicking starts about 10 seconds after the key is turned. sounds like some sort of relay clicking?
    btw the coolant is sputtering out when we have the rad cap off, the cap isnt broken
    we bled the system before when we filled it up and it was running fine, before the hose cam loose
  6. KTM mad
    KTM mad Donating Member
    down south. West Oz
    VT Wagon SII
    intermittant wiper turned on? hahahaha
  7. micky vn man
    gladstone
    vn v6 calias
    sure thats not ur electric antenna lol ..id do it all again..n fill it up once ur thermostat opens so theres no air bubbles in system..and i also know if the heater tap is broken the car does overheat.had it happen to me before on old vs
  8. Schwuppes
    WA
    ok you mean totally drain the block and start over?
    im hoping it isnt a blown head gasket... but theres no water coming from the exhaust and the coolant isnt oily...
    but just in case, what does it cost to get the head gaskets replaced.
  9. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    Close to a grand if not over, cheaper to do it yourself.
  10. accentstencil
    Eschol Park, Sydney
    The air would have entered after the hose came loose.
  11. SID888
    SID888 New Member
    Northern Beaches, Sydney
    VX1 5.7L Berlina Wagon A4
    Put the radiator cap back on and check. The radiator cap is a pressure sealing type, it increases the boiling point of the coolant and in conjunction with the coolant recovery bottle maintains coolant in the radiator.
  12. umair
    umair New Member
    saudi arabia
    Sold my car :(
    Usually the hose does not come loose by itelf, it is most likeley pressure getting generated and that caused the hose to come off. So your problem was from the start.
  13. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    ^^ I agree with the umairs post. If the cylinder pressure was leaking into the water jackets through a blown/leaking head gasket, then this would have most likely been the cause of the hose blowing off, as well as causing the the bubbling from the cooling system.. Sounds like it might be blown head gasket(s), do a compression test on the engine..
  14. Schwuppes
    WA
    thanks guys
    we got it sorted... had to wait until the engine was cooled down more, then we poured some coolant into the heater tap hose lol.... then bled the **** out of it and the problem went away
    She's actually running very cool now, after having it idle for almost an hours checking stuff, and then another 30 minutes drive home the needle was hovering between the first notch and half way mark on the temp gauge.
    I think I actually might have forgotten to tighten the hose clamp properly.... just shows how easy it is to make silly mistakes when its late and youre tired :(
