hot feet in vr
lookatya
68
adelaide
vr exec wagon
Is it just me or does anyone elses vr wagon seem to fry your feet because the foot well area is so hot.
has extractors fitted thought this may be something to do with it
or does it need more or some firewall insulation
Krisp
34
perth
D22 St-r Navara
would be your vaccum solinoid for your heater box
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
If there is hot air blowing down over your feet I'd agree with Krisp, but if the heat is coming up from the floor then I'd say your extractors/down pipe is a bit close to the body and/or needs a shield.
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
yep i agree with hako..i had extracts (pacies)in my old vs ute and wow the heat that came up from the floor was bad? also i had heat comming in from the handbreak as well? no wnder it was hard to cool her down in summer
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
is the floor actually hot or is it just hot air from the vents?
Vee-ard
QuickVR95II 2010 Survivor
Bayswater, WA.
Foam Tuned VR 5.0l Ute
If anything pacemakers should be cooler seeing as how they come ceramic coated, unless you had the wrong ones installed and/or had no heat shielding. I have pacies and can see no difference.
justbad4you
IF YOR NOT A HOLDEN
i think i didnt have heat shielding
was might warm,,,more so the heat that came out from under the drivers door was hot also......that old utes gone and the maloo dosnt have any of the same issues
bogan_vk
australia
commodore
my vr had alot of heat coming from under the drivers door with genie extractors .
justbad4you
IF YOR NOT A HOLDEN
same with the pacies> was shocker in summer.....and it came in from were the hand brake was as well
M4YH3M
Bendigo, VIC
1996 vs acclaim
my vs has extractors and i can always feel heat on my left leg coming from down near the foot rest
