I have something that may later become a problem to ask you guys. The motor on my car runs very hot now it runs fine and everything but when you lift the bonnet after even only like 1min of running time it's frying and you can't work on it until about 10mins or so. May i need to flush out my radiator or get a new one?
Radiator and Fan wouldn't be playing a part in it if it's overheating in the first minute. The three things I can think of are: 1)Waterpump 2)Thermostat 3)No water IN the cooling system.
My cars waterpump has just **** itself ... got the wobble and leaking coolant .. waterpump costs like $90 and say $80 for labor ...
Yea could be a few things, might not be holding pressure, thermostat, fan, waterpump may be even a headgasket. Diagnose the problem first before replacing things as you will just spend more money. Ild get a mechanic to do a pressure test on your system, cost like $30 from memory.
if it gets hot in less than a minute its most likely more than the thermostat.whats getting hot everything or just the manifolds getting hot
Well a coolant flush is fairly simple, just need a hose and some coolant. But make sure you be careful were you drain it if you dump it just anywhere you can get a nice stinkin' fine from the EPA.
