hotwired climate control to work VN
sik-holden
vn calais,vk calais padock basher
i have had to wire the realy up to get the climate control to work.
is this a common problem or is there a simple fix?
tim
88GreenVN
Next Exit Left
58
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
tim
What do you mean by wire up the relay to get the climate control to work? Was it in the car and stopped working - or are you fitting climate to your car?
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
He might be referring to the resistor. His car is a VN Calais so it would have climate air with the old style resistor fitted. Perhaps he's by-passed it because it had carked it?
sik-holden
resister? where bout is it?
and the little black box just above the battery, have high beam fuses theft horn etc and has a relay in there for the heater, i put it straight to positive and it worked, was like it wasnt turbing on with the key, any ideas?
tim
88GreenVN
Next Exit Left
58
Surprise, Arizona
tim
Did you try and swap a relay with the horn relay?
sik-holden
yep no differance at all
Calaber
tim
Hi Tim
I don't know if this is the solution to your problem, but the resistor is located underneath the plastic trim that covers the wiper linkage, which you can see when you open the bonnet.
There was a recent thread about replacing the resistor on the VN-VR models. Have a look for it, it came complete with photos so it was easy to follow. Much easier than trying to describe what to do here.
sik-holden
o yer that thing yer thats working fine, it was all working fine in the other car before it was pulled out and put into my car
Chirpstr
A new project attack
34
VR Berlina M5, VP M5
LP Check Relay is at fault. Swap it with a known good one then see how you go.
88GreenVN
Next Exit Left
58
Surprise, Arizona
So you have just installed the climate into your VN Calais.
Did you swap the main car loom as well?
