How A Turbo Works
Discussion in 'General' started by Leebo, Jun 4, 2009.
  1. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    actually he can also get done for violating license conditions. then he can expect a defect on the car also cause im sure they will not only throw the book at you but beat your head in with it
  2. Philthy
    Philthy That dent guy
    3.0R Liberty, XC Falcon
    I'm gunna go with the others here and say save the serious mods til you have a bit of experience, and the law allows it. A cammed, shift kitted VN will get you in enough trouble as it is.
    Save the money from the turbo and use it to pay the fines you will already be getting
  3. revv_head
    revv_head I DRIVE A V6 SS :P
    Sydney, NSW
    SS
    i think you just didnt understand my **** explaination.
  4. f1tzy
    f1tzy New Member
    Brissy
    FG XR6T Ute manual
    Na your explanation was about 90% wrong. The wastegate has nothing to do with the blow off valve, the air leaves the turbo before it goes through the intercooler if the car has one and the turbine spins on the exhaust gasses which spins the compressor wheel. The compressor wheel sucks the air in and compresses it before sending it to the intercooler.
    Did you read the link i posted earlier?
  5. Leebo
    Leebo New Member
    89 VN
    wow soz guys. forget the tubo I'll do other things.
  6. dons vs
    dons vs New Member
    vs ute
    just to summaries on how the turbo works.
    the exhaust gas from the engine is collected into one and goes through the turbine housing, which spins the turbine wheel.
    The turbine wheel is part of a shaft which goes through a bearing cage and on the other end is another wheel, this is called the compressor wheel, it also has a housing which is called the compressor cover.
    As the turbine is spinning and the shaft is connected to the compressor it spins that as well which sucks air in one side, compresses it and throws it out the outlet.
    this compressed charged air then flows through a set of pipe work into an intercooler if its fitted with one, then through another set of pipe work and into your throttle body.
    the bov is best mounted on the cold side of the cooler piping as close to the throttle body as possible so between the intercooler outlet and the throttle body.
    that has a diapgram and spring and is vacume controlled to realse the valve and leak the compressed charged air in the system out of the outlet of the bov which can be leaked to atmosphere which goes "ppsshhh" or can be plumbacked back into the intake pipe near the filter.
    The waste gate which in most cases is internally built into the exhaust housing or turbine housing simply acts as a boost controller.
    the more exhaust gas coming from the egnine the harder that turbine will spin and the more boost it will make, when it reaches the desired boost level the waste gate valve will open and bleed the exhaust gas off out the exhaust pipe before it gets to the turbine so it slows the turbine down and restrics boost.
    the waste gate is much like the bov with a diapragm and spring and is vac/boost controlled.
    Externally gated turbos are same thing only the waste gate valve isnt built into the turbine housing its a separate unit which will come off a pipe mounted onto the exhaust manifold before the turbo.
    they can either run an outlet pipe to atmosphere which is called a screamer pipe or they can be plumbed back into the exhaust system further down the line but before the cat to be legal.
    sorry about my spelling im cold and tired and just finished work.
  7. Leebo
    Leebo New Member
    89 VN
    Thanks for that dons vs, very thorough. Would i be best making a better foundation for the turbo to go onto when I'm allowed to have it ? a standard VL motor for example wont turbo well as the genuine turbo is low comp instead of high. Would i be best do do up my Buick 3800 and drop that in ready.
    I have brought a donor car with a rebuilt engine perhaps I'll get it across into my car first
  8. dons vs
    dons vs New Member
    vs ute
    If your on restrictions now then i wouldnt bother yet.
    maybe build a v6 on the side which will be able to slap a turbo on when your aloud to.
    legally you cant put a vl engine into your vn/vp as your not alloud to put an older enigne into a new car.
  9. stocky
    stocky New Member
    yes he can. VN is allowed an RB30. just ask vn_luke. he got his vn registered no problems with an rb30 in it
  10. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    Yep VL and VN had to pass the same emissions laws so its all ok.
  11. Leebo
    Leebo New Member
    89 VN
    nah not thinking of putting an rb30 in it but i have another Buick 3800 i can build up
  12. T-MaKK
    T-MaKK New Member
    VX/VY Executive
    is there any point in strappin a turbo to a 4cyl vectra?
  13. nemesis_adrasteia
    nemesis_adrasteia better to reign in hell
    longford, victoria
    VR commodore HSV(without all the gay ****)
    only if you want to go faster than you currently can
  14. dons vs
    dons vs New Member
    vs ute
    properly not worth the troubles and money mate.
    custom manifolds, cooler piping and exhaust.
    plus your turbo, and intake system
    will need bigger injectors most likely and at the end of the day how strong is a vectra? can it hanle 5-10psi?
  15. revv_head
    Sydney, NSW
    SS
    yeah i read it like 5 years ago. then read it again and thats what i had in my head. came out wrong.
  16. crew chief
    crew chief Member
    WK Stato with blurred plates
    you can hide your turbo setup to some degree, here's what i did to mine :thumbsup:
  17. BE39ER
    BE39ER More Torque Less Traction
    Newcastle
    94 VR Commodore Berlina just converted to manual
    What turbo :) I wouldnt have noticed it at all mate, you've done well
  18. Stressball
    Stressball Rolling on 4 again :D
    SE QLD
    Mitsubishi Triton
    Hidden turbo? Try this. The chrome is a bit attention-grabbing, but you certainly can't see a turbo in there.
    Also considerably more difficult to make it happen :p
  19. ari666
  20. VT-565
    VT-565 New Member
    QLD
    VT
    You would imagine most fuel systems being able to handle up to 5psi at the manifold with no component change over?
