How can i drain ALL the coolant?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by freefallin, Jan 19, 2013.
  1. freefallin
    freefallin Member
    UAE
    VY Berlina / VZ SS LS1
    I want to thoroughly drain the cooling system but i cant seem to get all the coolant out from the engine. Ive flushed it 3 times by now and everytime ive drained the cooling system by removing the bottom radiator hose. But that seems to drain only about 4-5 liters. I believe the cooling system holds 12 liters.
    So how can i completely drain the coolant from the cooling system?
    Cheers!
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    You will need to remove the knock sensors to drain it completely and that is more trouble than it is worth for most people.
  3. freefallin
    freefallin Member
    UAE
    I was afraid that might be the only way. Reason i want to drain all the coolant is cz i recently had a blown head gasket. Now im having a hard time removing all the oil from the cooling system. Flushing doesnt seem to do that great a job cz i still see some oil when i open the rad cap. I even tried flushing with dishwasher detergent. That worked way better than just water but since more than half the coolant was still in the engine...i couldn't get all the oil out.
    Any instructions on how to remove knock sensors?
  4. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VE Berlina
  5. JRNZER
    JRNZER Well-Known Member
    S2 VE SV6
    My flatmate blew the head gasket in his vl late last year and stuffed the engine. There was oil all through the system. He had to get the radiator dipped to clean it and have the whole cooling system professionaly cleaned out. Dont know how bad yours is but if there is still oil in the system I"d be getting it done properly.
  6. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    I don't know if trans fluid is much
    different to engine oil, but when the
    heat exchanger in my rad cracked and
    let heaps of trans fluid into the
    coolant, around
    30-45 minutes of flushing with water and
    there's not a trace of trans fluid in
    the new rad now.
  7. KustomKulture62
    KustomKulture62 Active Member
    Queensland
    2013 Specialized Hardrock Sports Disc 29er
    I to had the same problem when I recently replaced the radiator and some one in here said to remove the thermostat and run water through the engine.
    Look up, A radiator flush question: the guy who replied went into detail how to service the entire cooling question and fully answered the draining problem.
