How can i improve my VT's handling ?
-_-"
Central Coast, NSW
VT
Guys ,
wanna make the VT handle better , lots of body rolled even when changing lanes !
how to improve it ? already have new struts , new springs , both front and rear , few new bushes
looking at rear sway bar but seem to be a BIG job to change it !
should i get bigger rear swap bar ? what size ?
cheers
oska
vx custom 600RR
FE2 is your friend but can be harsh at times
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
Try a heavier front swaybar first. most of your cars weight is at the front. A heavier rear bar will make it handle worse because the back will want to step out if you do any hard cornering.
Longman
Newcastle NSW
VE Calais V 6.0 Auto
if you don't already have one, I'd chuck a strut brace on as well. I put one on and made a big difference to the amount of body roll around corners, and cheap.
sus_038
33
VT S-Pack S2
Deff get a strut brace, huge difference i got one in my vt s-pack along with FE2 bigger sway bar and nolathine bushes :)
ashbox
back in black
The Car
something black
strut braces, sway bars, springs and shocks
2DIE
ONEDOLLAHOLLA
South Aus
www.torn.com
97 Acclaim
Just asking instead of making a thread somewhere else.
Don't the strut braces require holes to be drilled in VT or is that only for the ones bought from Holden?
DLFHUB666
GIT 'EERRR DONE!!!
Nhulunbuy NT
VX SS, PX Ford Ranger XLS Dual cab
You gotta drill holes to fit a strut brace (holden or aftermarket) to a vx, So i would think the vt would be the same.
sus_038
33
VT S-Pack S2
Yep VT is the same, but trust me, worth it :)
