How can i tell the difference between a 225kw, 235kw and a 245kw v8 engine?
Discussion in 'VY Holden Commodore (2002 - 2004)' started by freefallin, Nov 22, 2012.
  1. freefallin
    freefallin Member
    UAE
    VY Berlina / VZ SS LS1
    Im trying to buy a 245kw 5.7 v8 engine. There are a couple of places that sell used engines but the problem is they just call them v8 commodore or caprice engine! Since there are 3 types of v8 engines, how can i tell the difference?
    Also, is the vy ss engine the same as a vy (lets say Calais) 5.7 v8 245kw engine? Would it fit in an ecotec engine bay?
  2. aussieakito
    Melbourne, Victoria
    serial number?
  3. freefallin
    freefallin Member
    UAE
    what serial number?
  4. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    I'm not a 100% sure but I'd say most of the power differences would be in the tunes and not the motors themselves.
    PJDM1980
  5. IRON8
    IRON8 Let It Rip
    Auckland, West Harbour
    'VTank SS , VG/VR Ute
    Yip, itl be just the tune and i think the hsv had better exhaust incl headers
  6. cander24
    cander24 New Member
    NSW South Coast
    VZ GTO. VS LS1.
    No difference in the motors. Power increase was achieved through a combination of tune and exhaust (depending on model).
  7. freefallin
    freefallin Member
    UAE
    Oh so a commodore or caprice 2000-2004 v8 engine blocks are all the same no matter in which model car, including ss?
  8. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    Also you will need the V8 K frame if replacing a V6 as they have different engine mounting arrangements.
  9. IRON8
    IRON8 Let It Rip
    an LS1 is an LS1.. not like the Holden V8s where you need a degree in Holden V8s to know them all
  10. freefallin
    freefallin Member
    UAE
    didnt get you there
  11. freefallin
    freefallin Member
    UAE
    what else will i need to replace/change? Transmission? BCM??
  12. Munz
    Munz Right Foot Action
    Brisbane NTH
    VZ Calais LS1 / VL RB30e daily
    Go for a later model LS1 2002+ as you should pick up the LS6 block make sure casting number is: 12561168
  13. IRON8
    IRON8 Let It Rip
    no did you
  14. pjdm1980
    Geelong, Victoria
    Why don't you just buy a V8 powered car, surely even in the UAE's it would work out about the same if not a bit cheaper and you'd have a factory V8?
  15. freefallin
    freefallin Member
    UAE
    cz im swapping my v6 and saying a difference of only about $300
  16. freefallin
    freefallin Member
    UAE
    So anyone know what else i need to change to make the transition?
  17. CONROD
    CONROD Member
    SOMEWHERE in the land of OZ
    VZ SS THUNDER 6.0l 6 Sp
    LS1-GEN111 in a VT/VU--225kw @5200 rpm
    LS1-GEN111 in a VY------225kw @5200 rpm
    ----------------------------- 235kw @5200rpm--high performance dual exhaust
    LS1-GEN111 in a VZ------235kw @5600rpm-SS CREWMAN
    ----------------------------- 250kw @5600rpm-SS UTE
    These figures taken from original GMH sales brochures
  18. cander24
    cander24 New Member
    NSW South Coast
    VZ GTO. VS LS1.
    Complete motor with all bolt ons, gearbox, wiring harness, pcm, bcm and matching coded keyhead, tailshaft, k frame, v8 speedo cluster (or have your current cluster modded to suit), radiator, airbox and intake, exhaust, metal coolant pipes (the ones that sit on the k frame infront of the harmonic balancer), heater pipes.
    I think that's about it.
