oh yeahh, but that takes long to read and find it , a simple explanation would be nice, but dont worry il have a look @ it 2morro
If you open your bonnet, there are 2 holes on top of each headlight to put a Phillips head screwdriver. 1 hole is for up and down, the other is for left and right.
i had a look @ the head light and no screws but there was a nut with allenkey top to go left/right and next to it right under is a nut to go up and down?? i think thats it
On mine those nuts also have Philips head indentations on them, so a choice of either screwdriver or ratchet/ socket to use. Sent from my Galaxy Nexus using Tapatalk
If you have aftermarket lights then the philips indentation is usually pretty useless. Just get a hex head driver. Park your car about 20meters from a wall on level ground (underground shopping center car parks are best) Adjust it like this The blue line should be about 5cm closer to the ground than your headlights are from the ground. The red lines should be the same distance apart that your headlights are.
