The back of the old wagon is getting a bit clunky, and i had a look at the rear control arms and basically some are completely shagged and some are half ok. So i want to replace them all(upper and lower control arm bushes). Do they need to be pressed in and can can i do it at home with a hammer, or do i need to take them to somone to change them out properly? I think the uppers might be easier to buy a reco'd unit but ill await to see what you's recon. Thanks
i used to do them all the time. cant remember the exact method. they easy as only thing is the rubber bushes have to sit a certain way. or i was always told anyway. definately can be done at home.
Yeah i seen them on there, but they only come with rubber bushes. The ones i got have poly bushes and i would like to put them back in, as i keeps the rear end nice and solid.
