How do i clean my Pickup/Sump. Picture included.
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Deneo, Jun 7, 2010.
  1. Deneo
    Deneo Lock your Daughters up
    Western Suburbs
    VS HSV Statesman
    hey guys.
    Finally got to the bottom of my oil problems i'm thinking.
    What's the best way to clean all this **** off the Pickup and All the **** out of the Sump?
    Cheers Deneo.
  2. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Diesel and a paint brush.
  3. sik_dose
    sik_dose Hybrids. Cars for fools.
    1986 VL Calais Turbo, VZ SV6
    change your oil every 5000km and this wont ever be an issue. its going to be a prick to clean.
  4. Deneo
    Western Suburbs
    VS HSV Statesman
    Only had the car for a few months, If i was the owner since it was released it wouldn't look like this lol.
    I got most of it off brushing lightly with a peice pf coathanger will go over it with diesel in the morning.
    There looks to be half a tiny gasket in the sump. Don't know if it's spun a bearing in the past and been repaired or what :S
    Thanks Deneo.
  5. moff_man
    moff_man operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    ring an engine reco place and see if you can acid dip it. thats the best way to clean it.
  6. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    i cleaned my oil pick up and sump with degreaser and brush worked really good
  7. GTP 85
    GTP 85 291 hp @ the wheels
    Murray Bridge S.A
    MY04 WRX, VS SSenator & VS V6 track weapon
    Should be able to unbolt the oil pickup if i remember correctly...?
  8. VS_Pete
    Correct I bought a new one.
  9. Deneo
    Western Suburbs
    VS HSV Statesman
    yeah, Cleaned it with a few liters of diesel, Alot of **** in the pick up and sump! All back together now, Get the verdict when i get a sump plug washer tomorrow! only thing that's not in. What a mission it was though!!
  10. VS_Pete
    This happened to my v6 it was getting 10,000k oil changers for 10yrs. with Magnatic **** oil.
    Another guy I know had the same trouble with Magnatic oil.
    After it was put back together I did a couple of 2500k oil changes and filters.
    I cut open the filters to have a look and there was little balls of crap inside not a lot.
    Now my oil is pretty clean at change time.
    Cost a bit to do but cheaper that a seized motor.
    Good luck with it mate.
  11. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    A mate I know had a air line connector brazed onto an old oil filter. Every time before he changed the oil, he would remove the old filter and replace it with his modified one, then connect the air set at 60PSI and give it a good blast. He reckoned the backflowed the pickup and stirred all the hot oil in the sump up...also blew all the old oil from the gallerys/lines. The then drained the oil and primed the new filter with fresh oil before filling the sump and starting the car. More than one way to skin a cat.
