how do i clean the engine and bay without damaging anything?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Brysha89, May 13, 2020 at 9:12 AM.
  1. greenacc
    greenacc Searching for the billion
    VE Berlina
    Yes the sca degreaser is probably not the strongest, but anything that doesn't dissolve with the first spray, or any really dirty areas I rub with the brush and they disappear with a second blast of the hose.
    And I always wash degreaser off. Leaves a much cleaner surface.
    krusing likes this.
  2. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    Slug powered VZ, a VE Calais & your mum.
    You can get the 303 at Supercrap & Repco if the fkwits at Autobarn make you want to punch them. I bet Bursons sell it too.
  3. Fu Manchu
    WA
    Yes, I use a low pressure garden hose.
  4. Fu Manchu
    WA
    It would be a P clip. They are a P shaped clip that hold trans lines and fuel lines on. Sometimes wiring harnesses. They have a rubber lining on them. If that’s what they are talking about I’d tell them to get Fkd. *Like when one shop tried to tell me I needed a new clamp after I’d just bought that clamp a day before and fitted it myself (correctly).
    Disconnect the negative terminal on the battery OP.
  5. Fu Manchu
    WA
    Some of my fav detailing people doing engine bays.
    Forensic Detailing
    Go to 21mns for one of the detailing world’s guru’s take on engine bay cleaning. Ammo Detailing
    Pan The Organiser
    Sandro from Car Craft Detailing in Melbourne. Great guy.
    lmoengnr likes this.
  6. VS_Pete
    Fu Manchu likes this.
  7. shane_3800
    shane_3800 Active Member
    places
    vr commo
    I don't know why you would cover the alternator? Oil and dirt makes it way into them over time the absolute worst thing for one is oil. I've seen oil kill a lot of alternators I've washed hundreads and never had one fail I've likely increased their life span because they were covered in oil.
  8. Fu Manchu
    WA
    I cover mine now ever since the one in my VP shorted out and caught fire. Also why I now disconnect the battery. Prior to that, never covered alternator in decades.
  9. shane_3800
    places
    vr commo
    Water it's self has too high of resistance to let 12v pass through at any decent current at distances over cm or two. That sounds odd.
  10. Fu Manchu
    WA
    Yep, but it happened and that experience changed how I do the job.
  11. shane_3800
    places
    vr commo
    Yea when I was an apprentice my mate had power steering fluid leaking on his alternator in his VX SS and it died I said it should be fine I was wrong. I think the oil eats the enamel or it attracts dirt that rubs through the enamel???
    Maybe with you VP the water and soap picked up a whole heap of brush dust and created a high current draw???
  12. Brysha89
    Brysha89 Active Member
    Melton,Victoria
    WM Statesman L98 6.0ltr
    So i went out to clean the engine and bay today here's how it went with just 2 jacks and 2 stands as don't have ramps atm cleand it the best i could starting from the start dirty: nes stato 1.jpg new stato 2.jpg
    Rear Main section: Dirty
    Sump: Dirty
    Top and Rocket Cover's: Dirty
  13. Brysha89
    Melton,Victoria
    by just on stand's and jacks using cheap motortech de-greaser 4 cans and my pressure washer
    Sump and Tranny: Cleaned
    Rocket Covers and Head's/Extractors: Cleaned
    Looks like i need to pull the engine out as it looks like its surface rust on it now the car was brought from Geelong but its clean enough to see where leaks are coming from im just waiting until it drys moor then im going to run the engine for 20 or so mins to get it warm and see where the oil comes from. Thank's all for you're comments
  14. figjam
    figjam Donating Member
    Port Stephens area.
    Monaro CV8, Cross 6 Crewman, Territory Ghia.
    Hope it starts OK for you.
    VS_Pete and Lex like this.
  15. Brysha89
    Melton,Victoria
    it will i checked all electric leads after the pressure wash and alternator was covered as suggested
  16. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Need to be careful of TPS. Although I can not confirm 100%, I suspect that is why I have had 3 or 4 them fail in under 12 months, each time. It seems they fail a couple of months after a clean. I have now resorted to wrapping the TPS. On early V6 they say watch the DFI and coils but mine get wet and they haven't played up yet. I don't deliberately blast them though, just in case.
  17. losh1971
    North Tas
    VR Ute V6
    I'd say it has a similar affect that it does on a starter motor. On s starter it arcs out the brushes and sometimes takes out the solenoid at the same time. Some cars a notorious for failing starters and it's all because of a leaking oil filter adapter oring. I've pulled a few apart and found them caked.
  18. Vin999
    Vin999 Active Member
    SA
    Vsedan
    Those cheap lil steam cleaners with small nozzles with a paint brush are good, quick and easy to remove sprayed on degreaser, easy to keep away from electrical parts. Me and a mate use to detail cars for a few car yards on the weekend for extra money before all the detailing/carwash trade went professional :)
