How do I install genuine cruise control on a vs executive?
Ryan272
VZ Lumina
g'day,
I have a vs executive wagon without cruise control but i purchased a genuine cruise control system of someone who was wrecking a vs wagon with cruise.
i got the cruise indicator stalk aswell as what appears to be the cpu with the throttle cable but i'm sure theres stuff missing, can anyone tell me exactly what i need and instructions (or where to find instructions) on installing it?
thanks.
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
Marking thread to :)
markovr
59
northside brisbane
www.cardomain.com
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
I have the wiring I took from a car at the wreckers that had cruise control fitted at the dealeras a kit if you need it...however some up market models have the wiring already in the loom and also have the instructions that was in the glovebox of the same car of how to do it...see if I can dig them up.
Ryan272
VZ Lumina
hey markovr,
yeah if you could dig those up that would be awesome!
i had thought that i might already have the wiring there but without knowing exactly what i was doing i didnt wanna go digging around.
thanks alot, hope you can find it :)
centy
Vp series 2
I just picked up a exec and was planing to do this to.
Mine has the cruise wiring in the loom.
Its been stuck in the channel on the pass side of the engine bay.
I would expect to be able to pull it out and hook up to a cruise module then inside fit the cruise brake switch, wirinf ther for it to. then fit a cruise stalk. haven't look to see if the wires are in the column yet and fit a relay which has contacts in the box allready.
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
I recently installed factory cruise on my VS 2 recently....I bought a VS cruise module on Ebay ($50), cruise indicator arm + extra brake switch + small CC relay from a wrecker ($55). You must have all these components.
All wiring is already in the car - you need to drill 2 holes for the module in the engine bay and the rest is plug and play. I used links from this forum to help me.
Series 1 VS may not have the wires installed already which makes it a bit harder.
I'll dig up the posts I found extra helpful and post.
Good Luck.
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
Is a VS S1 Manual ute likely to have the wiring, im thinking not? :(
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
