How do I install genuine cruise control on a vs executive?
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
heres what mine looks like
and with the actuator off the throttle bracket
AussieHolden
Australia Victoria Geelong
VZ Executive Wagon 2006
Oh Great now I get told that I have to change my BCM from LOW to MID for the cruise to power up and there not easy to come by grrrrrrrrrr.
CCCMikey
Black Mountain NSW
VS '95. LPG. 513,000KM
Is it possible to add Cruise Control to a '95 VS Executive that has aftermarket LPG installed?
jeepyrocks
BMW 535D, VR V6 Ute
Yes; cruise only controls the throttle plate- which is in use on both petrol and LPG.
torana50
VS Ute S2 V8 T5
Here it is..a little large and its for a vr...vs has a different v6 engine throttle bracket and its bcm/keyheads dont need changing and it uses a half size relay in a spare spot above the fuses for it
Just found this, awesome info still. thank you.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
Getting the correct patch loom is now the hard part to locate. There are a few different part numbers on these looms, and then there's VS which is another can of worms. Most Execs didn't have the provisions to add the components while cars which had ABS fitted as an option have the wiring all included.
