How do i install stebel air horn in my VE Calais?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by gottavecalaisv, Feb 9, 2012.
  1. gottavecalaisv
    gottavecalaisv Member
    2013 Vf SV6 Jungle Fever
    Hi all, just wondering if anyone can help me with instructions on how to install a Stebel air horn in my Ve Calais. I realise i will have to use a relay, where do i get power from under the bonnet? I presume i can use the factory horn switch as the trigger? Any help would be appreciated
  2. womble66
    womble66 New Member
    Illawarra NSW
    07 VE CALAIS V - V6
  3. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    Yeah Id say you would unplug the connector from the exisiting horn and use that? Calais may have 2 horns so d/c both and use one for trigger and tape the other one up so it doesnt short.
  4. mint
    mint New Member
    n
    VE
    Ten characters
  5. gottavecalaisv
    All fixed, just connected it which the existing wiring and works fine, very loud and European sounding. Very happy with the result
  6. aedeau
    aedeau Member
    My 10 VE SS ute AFM
    old thread, I know...
    I'm going to buy one of these. Did you install the relay that comes with it, or was it literally a direct swap over job?
  7. RiCeY
    Australia
    Standard horn has a relay so just do what the other guy did.
  8. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    are these legal?
  9. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    No not technically, air horns no, electropneumatic no, electromagnetic yes.
    The Stebel HF (high freq) and HM (main) are direct replacement horns, the HM 80 Magnum Twin (I have this one) is 3db louder x 2 horns and looks, fits almost exactly the same.
    I also have twin truck horns that I am looking to fit with a remote switch (because they are illegal).
  10. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    Perhaps you may wish to elaborate and provide us with the reference to the Australian Design Rules (ADR) in respect to 'horns/warning devices'.
  11. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    Um no thanks officer.
  12. jr_
    jr_ Donating Member
    VE II Sportwagon
    Thanks for info PIR4TE, I was looking online today at Stebels and was about the put this idea in the too hard basket
  13. G-No63
    G-No63 New Member
    My10 VE SSV
    I added a Marco tornado horn which is the same as a stebel nautilus to my MY10 VE SSV. The SSV comes with 3 horns, one in the engine bay for the security options and one on each side behind the driving/fog lights. I used the one on the passenger side which requires removal of the wheel and most of the plastic cover inside the arch. I removed the original horn, drilled the bracket out and fitted the new horn to the original bracket,( I tried the drivers side first but the offset is opposite and it didn't clear everything. You could fiddle around with brackets and get it to fit if you wanted to. I should also mention that I've had an Over The Radiator intake fitted and have to admit I didn't take any notice of where the original intake came from so I don't know if it would get in the way). I then used the original horn wires to operate the relay that came with the horn. The horn specifications state current draw as 18amps, the original fuse is 15amp. Fuses are put in line to protect wiring, not the end product, there is no way I would connect the horn to the original wiring connectors or put a higher rated fuse in the original holder and risk damage to a wiring loom, or worse, a fire. So, I put in a new fuse from the jump start post in the engine bay and ran it behind the original air box position and down to the horn, completely covered in split corrugated plastic tube and ran the negative back up to the chassis post near the air box. I left the original horn on the drivers side connected and when I hit the horn button they both operate. If there is a legality problem with the air horn all I have to do is pull the new fuse out and the original horn on the drivers side still works
