gunsmoke
Gunsmoke
- Jun 23, 2009
- 207
- 0
- 0
- Location
- Perth metro
- VE SS & VZ Exec
Can someone give clear instruction how to remove the BCM on an '04 VZ V6 Exec sedan and how does the fusebox come out. Thanks.
>>>>>>>>OOOOKKKKKAAAYYY<<<<<<<<< I just found out the BCM is actually just above the brake pedal not near the fuse box...... firstly remove a black plastic cover above the pedal and the BCM is a long rectangular grey box about 200mm x 75mm wide with four main plugs connected to it. remove the plugs THEN yank downwards. It has BCM written on it and mine has "MID" also on it. Others may have low or high on them.
The fuse box doesnt need to be removed at all. The BCM can just be seen if you lie on the floor and look up right next to the Go pedal with a torch.
Good luck.
Good luck.
