Wherry951
PROJECT UNDERWAY
Hey i need urgent help by Friday on how to do this. I have shredded the universal joint rubber coupling at the front, on my VT S Pack manual. Its not the cross looking uni joint by the way
I bought the new part for $180 today, and i need it fitted for Friday as i have work Friday night.
The car is currently jacked up and on 4 axel stands. My mechanic has told me all i need to do is undo a few bolts and remove the tail shaft, apparently its that easy, then slot off the old joint and put the new one in and put back together. Just want to check its this easy
I have also read somewhere the transmission will leak when tail shaft is removed. Will it leak so much i need to replace? And what kind of fluid that leaks will i need to replace, remembering its manual.
Dont want to stuff it up or anything, so just getting a bit of advice and re-assurance. If anybody knows of any guides to do this on the internet please link me, remembering it is NOT the cross pattern universal joint, its the front rubber coupling. Looks like a big circle/hexagon part with bolts around it
Thanks
Thanks
