How Do I Stop Rattle From Subs (or atleast make it a bit quieter).
Burger43
Australia
Holden Vs Calais SeriesII & Holden VZ SS MY06 6.0L
hello i am wondering how to stop, or reduce the rattle in the boot from the subs.
im sure there would be a few people thinking the same thing so i made a thread!
sweefu
VY Berlina V6 / R31 Skyline
Please, do a search. What is rattling? Find what it is, then shove a piece of foam in between the two surfaces
MAG00
VY S2 Calais
Huge issue is the number plate. Go get yourself some rubber washers/grommets/whatever and chuck them on the screw, in between the plate and the car. Put a foam strip across the bottom of the plate if it is only attached across the top.
Pickle'
Donating Member
Sydney, NSW.
VE Omega
i took about 3m x 1m of bubble wrap from work and crammed that in everywhere.... boot weighed alot more.. but stopped rattling.
Expanding foam seems a little smarter.
MAG00
VY S2 Calais
Expanding foam is dangerous if you're not careful. I have seen people put far too much of it inbetween sheets and it expanded to the point where it bulged the sheet metal, leaving a nice imperfection visible on the outside of the car. So if you go down the expanding foam route, just exercise a bit of common sense/caution.
sweefu
I was half kidding, but yes be careful, it can be useful between panels.
Burger43
Australia
sweefu, what have you used ?
