how do i take my fuel lines off
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by MON57A, Feb 17, 2006.
  1. MON57A
    MON57A Guest
    im disconecting my engine on my vs commodore and i am having trouble taking off the fuel lines off because of a special bolt that has to be squezzed out?
    look i have no clue so any HOLDEN lovers that can help me out will be much appreciated!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. TheForgotten
    TheForgotten only human......
    quarantine
    VR EXEC
    ummm... bolts can't be squeezed out, and it they can then they're RS.
    should be as simple as undoing hoise clamps on fuel lines and pulling hoses off the lines and rail
  3. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    They are all hose clamps on the fuel lines...on my car anyway...Ichanged them all to the endless jubilee type...the old factory ones screw up and cant go any further and then leak.
  4. grigor
    grigor New Member
    VS Executive, R31, R33
    Presume you're having trouble with the quick release connectors at the firewall?
    They need a piece of thin split plastic tube, similar diameter as the steel pipe and about 25mm long, that will slide over the steel pipe.
    Push the tube up into the quick release connector at the same time push the connector into the steel pipe. You'll hear it click then just pull it off.
    I made mine from the top of a biro.
    I first tried some black poly from the sprinkler system, which worked but was a bit flimsy.
  5. newo
    newo New Member
    Melbourne's West!
    VS Berlina
    Gregory's manual states to use a pen lid, cut the top off, and put a slit down the side.
  6. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    VE OMEGA 3.6L Dual Fuel
    You can get that special tool from Repco..
