**how do you paint plastic bumpers?? any special paint???
VK-Berlina5.0
turbo setup would be good
down south
VK 308
**how do you paint plastic bumpers?? any special additive needed??
what do you use to paint the plastic bumpers etc... on cars?
im painting the bumpers the same colour as the car.
do you need to add a special additive for your paint so that the paint sticks to the plastic and can flex without cracking?
what do you use for filling up chips in the plastic bumpers, polyester or putty?
or do you need a special filler?
does anybody know what to use?
Cheers...:bow:
Scott
1vngal
North Tassie
'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
There's a type of bog that come in a tube thats awesome for stone chips, small scratches etc. I'll go out to the shed in a sec and see if i can find it for the name of it.
No, no aditive for the paint. It's all in the primer. You'll need to use a plastic primer, instead of your average primer you'd use on metal.
1vngal
North Tassie
Ok, I've been out to the shed, (And it's friggen frezzing out there!) It's called Evercoat Ever-Glaze & Spot Putty, and it comes in a red 454g tube.
hakhawk
smooth moderator
Staff member
you can actually buy a "bumper primer" specifically for the plastic bumpers, but plastic primer will usually do fine as 1vngal said
90VN55
34
stanthorpe, qld
90 VN SS 5speed, '90 VN Calais 5speed
this is what the plastic primer looks like
it also comes in a spray can
89vncommy
www.cardomain.com
VN Caladore
There is also an additive that you can add to your paint so it flex's with the plastic... When you see cars that have been in accidents, and the paint has peeled a little, and you can pick flakes of it off... That is when the additive is not used… I haven’t sprayed since 1996 so it could be included in primer by now…
Hairy Eater
Banned
46
Queensland
2000 VX Executive V6
ADAM... do you brush or spray that primer thats in the 1 liter tin ?..
VK-Berlina5.0
down south
VK 308
thanks for the help.
so if i use that Flexi Primer it should be allright and not crack or flake?
is there any thing else i need to add to the paint?
Cheers...
Scott
