How do you remove pcv valve from a VN V6 series one
Susanna
55
Wyndham Vale,VIC,3024
Vn commodore
Hi
Thanks for ur help on my last thread.
I need to remove the pcv valve on my VN V6 series one commodore to clean it. Taking that upside down "U" hose is easy, but not sure how to take out the actual pcv Valve....is it screw in/out...or do I just pull it out from the rubber grommet on the engine??. If so it's pretty hard..
Need help on this one guys.
Thanks once again
immortality
Staff member
Sth Auck, NZ
It should just pull out of the rubber grommet.
immortality
Staff member
Sth Auck, NZ
It's been there 27 odd years? It's probably got some built up **** holding it inplace and the rubber has probably gone a bit hard. Spray some WD40 around it and work it a bit and it should pull out. Rubber grommet stays in the manifold.
Susanna
55
Vn commodore
