How do you remove the discs?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by ascension24, Feb 11, 2007.
  1. ascension24
    ascension24 New Member
    On my ford you took the wheel off then pryed off a center cap and there was a big nut holding in the bearings and then the disc slid off.
    I had a quick look at the VR, but wasnt sure how to get the discs off, any help?
  2. Philthy
    Philthy That dent guy
    3.0R Liberty, XC Falcon
    In the how-to section someone has written one up for changing the rotors on a VY or something. It was exactly the same on my VS.
    When you have removed the calipers the disc will theoratically just slide off but mine took quite a bit of 'encouragement'
    Its not that hard at all really
  3. AndyVKSSA
    AndyVKSSA New Member
    darlington
    VR caprice 5ltr, VK group 3 rep 5ltr
    iv just finnished doin this on my VR SS, once the calipers r off spray the whole lot with WD40/RP7 or sumthin similar, get a rubber mallet and hit the rotor from the back and it should just slde str8 off
  4. Cheap6
    Cheap6 New Member
    VP Exec
    It is easier, and just as effective, to hit the disc from the side facing you (outside) with the rubber mallet. A steel hammer and block of wood can be substituted, and neither should hit the disc very hard; a series of lighter taps is better than a few big hits.
    Some anti-sieze compound applied between the disc and hub will make it easier next time.
  5. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Ixnay on the anti sieze. It has a habit of flaming during hard braking. The heat generated will burn it. Just use WD40 or the like when removing, they never really rust on that tight anyway.
  6. The Darkness
    The Darkness Junk Yard Dog
    Ipswich
    Charged VT V6 A4
    lol i thought it would have been harder then that. just sum WD40 and a rubbermallet and its as simple as whacking it loose. sweet i'll do my own now
  7. Cheap6
    Cheap6 New Member
    VP Exec
    I've always used it, since that is what GMH recommend, without any problems. Perhaps there are anti-siezes and anti-seizes. I use NeverSieze.
  8. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    True. Just make sure you use non flammable or stuff with a very high flash point.
  9. quiksilv3r
    quiksilv3r New Member
    Morayfield
    VSII L67 Statesman
    If you want a write-up I have done one for another site with pictures - step-by-step on the rear of a VS Stato (some would say too many pictures :p)
    Let me know if you want it and I'll dig it up
