how far past empty can you go
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by benno9911, Jul 8, 2010.
  1. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    my fuel was on empty and light was on so i went and got fuel and i filled it putting 53L in and i was reading about tank sizes and it says 63L stock so i had 10L left my question is can you use them 10L or cant pump reach it
  2. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    you can go past empty til you run out.
    Jesterarts likes this.
  3. benno9911
    Warrnambool
    03 VY S2 Exec
    dont want to go that far
  4. stocky
    stocky New Member
    Go to a servo?
    Fuel tanks can get dents in them and hold less. Light usually comes on at 10L
  5. wortus
    wortus Active Member
    It's a good idea to keep as much fuel in there as you can as keeping the pump fully submerged will help to keep it cool which may extend it's life.
    After the ligh tcame on I wouldn't drive it much more than 50km and certainly not past the next servo.
  6. immortality
    Sth Auck, NZ
    till it goes chug chug cough cough. there is normally 3-4 liters of un-usable fuel in the tank. with a decent dent that gets worse, especially if it's like mine and it's right under the pick up :(
  7. admir87
    admir87 Member
    vs calais
    ive heard the light comes on with 8litres to go.
  8. ethann
    ethann Low And Luxurious!
    Newcastle, NSW.
    '11 WRX, '73 Stingray, Lifted/Locked GQ.
    Pretty sure if you read the book that comes with your car, (In mine anyway, VR buick) It says it's ment to come on at around 12 litres.
  9. jokerflingo
    jokerflingo New Member
    Holden VY SS 2003 - 6 Speed Manual
    Is there really a need to run it that empty? Unless in certain circumstances.
  10. Hektic
    Hektic Donating Member
    2006 VE SSV Ignition Orange
    i was told to keep it above a quater other wise ur fuel pump will eventualy burn up
  11. benno9911
    Warrnambool
    03 VY S2 Exec
    i was asking casue i want to throw a new fuel filter on and i wanted to get rid of some crap out of the bottom of the tank
  12. Philthy
    Philthy That dent guy
    3.0R Liberty, XC Falcon
    Do you have a level 3 cluster? Hold "set" (or is that "mode"? I dunno, one of them) when on average fuel screen and it'll show you how much is left in the tank.
    No idea how accurate it is though
  13. benno9911
    Warrnambool
    03 VY S2 Exec
    yer i do have a lvl 3 you have to press mode and set when you turn the car on
  14. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    Try as Philthy suggested...You can calibrate it when you fill right up too.
  15. vn_v6
    vn_v6 Blumpkin
    victoria
    87 vl limited edition
    mate ha a vt, were driving to mildura, gauge went to e, trip computer said 0, drovve for atleast another 15
  16. matty m
    matty m New Member
    townsville qld
    vr stroker v6
    in my old vn once the top of neddel hits the bottow of the E enough line i knew i had about 10 bucks fuel left if that helps ya
