wortus
- Dec 2, 2009
- 1,885
- 22
- 38
- Location
- Sydney
- VY Series 2 25th Anniversary in Phantom Mica
If your horn stops working it may be a worn out spring loaded contact which is part of the upper bearing assembly on the steering column. To replace it with a new one requires a whole new upper bearing assembly and a fair amount of work.
An easy fix which has worked well for me is to remove the steering wheel and using a suitable soldering iron put a blob of solder on top of the worn contact, do not overheat. Additionally a small brass nut can be soldered there if you want a harder surface. The solder blob should last for several years and can be reapplied easily when it wears out.
