how is cruise control behavior controlled?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by pillzor, Jun 2, 2010.
  1. pillzor
    pillzor New Member
    VS executive
    just wondering because u know sometimes you can have it set at 60 then turn it on after coming out of a 40 zone and it will throw you back in your seat , other times it accellerates like a granny.
  2. ephect
    ephect Donating Member
    VS Acclaim V6
    i dont know how exactly but what i've found is depending on the current speed and revs whether it kicks down a gear or just accelerates using the current gear, and how close ur speed is already to cruise's set speed.
    i hope that makes sense
  3. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    Its set by the accelerator cable. The 'throws you in the seat'/'granny' effect is just dependant on the gear the car is in at the time.
  4. juzzyx
    juzzyx New Member
    04 VY Wagon
    I know what you mean. When I have my cruise set at 50km and push set accel it revs up straight away. Shoots straight up to 2600rpm. Scared me the first time I did it lol.
  5. Trayner
    Its a cool trick to do it thou lol haha, have it like set at like 60 and your cruising around at 40, then all of a sudden mass in the back of your seat affect :p
  6. pillzor
    pillzor New Member
    VS executive
    i might experiment with it in 1st and set it too 60 , then hit cruise at 40 and see what happens haha.
  7. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    haha bet the cops will never beleive you if you got pulled for loss of traction nah bro was the cruise control LOL set it to 100 and try it :D
  8. pillzor
    pillzor New Member
    VS executive
    in first ? :D
  9. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    dang if only my cruise would work
  10. pillzor
    pillzor New Member
    VS executive
    so i went ahead and tryed setting the cruise too 60k and engaged it while in 1st gear at 40 , the results were dissapointing :(
  11. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    It also depends on the load on the engine which directly relates to the slope of road you are on. EG if going up a hill at 40 and cruise is set at 60, when you engage it, it will throw you back more than if you were on level ground.
  12. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    If the cruise cable is not correctly adjusted it can cause this problem. There should little if any free play at idle.
