Adrian's Vr
22
Vr commodore manual
Hi all just wondering, i have a VR with a T5, i recently bought a pedal spring that pushes the pedal up, now my pedel is "unadjustable" so does the GM spring push the pedel to the floor or and i adjusting it incorrectly?? Thanks
gtrboyy
vt ss & lc gtr
From memory if spring is working pedal hits floor with clutch cable removed otherwise incorrectly fitted or broken.
You adjust cable at clutch fork untill pedal is at correct measurement to floor with tape measure...different height for v6 & v8
Adrian's Vr
22
Vr commodore manual
Alright so it is meant to go down not up, ill upload a picture of a gm spring to we can see if it will be correct
Adrian's Vr
22
Vr commodore manual
So this spring will pull the pedel to the ground and be able to be adjusted upwards (not like my other spring that i bought that sprung the pedel up)
gtrboyy
vt ss & lc gtr
Vaguely remember google diagram or one posted on forum was incorrect but if you fit your head under you'll see the wear marks on pedal how the original was fitted before it broke.
You notice broken spring when pedal pops up hitting bracket at bottom of dash...has no takeup feel,adjust cable it still feels same.
Got cramped trying to change that thing but worth the effort!!!!
BlackVXGTS
Melbourne, SE
The attached file from the Holden VS Service Manual may be of help to you:
  • VR-VS Clutch Pedal.pdf
