how many k's out of a supercharged 6 ecotec
Discussion in 'General' started by lowrida56, Jan 27, 2008.
  1. lowrida56
    lowrida56 Member
    VN Calais 5ltr
    how many k's are people getting out of a supercharged 6 ecotec? is it much less than a n/a ecotec?
    also how many k's will the charger do before needing a rebuild?
  2. lumina01
    lumina01 New Member
    Melb
    MY10 SSV UTE
    id say you'd get more out of the l67, in the process of buying 1 at the moment and have a na ecotec aswell so will find out sooner or later
  3. greenfoam
    greenfoam New Member
    VP Executive R-spec
    I have a friend, his L67 chucked a leg out of bed while driving only the highway at 2000 revs, so random. It had 104,000 ks on it
  4. HoldenMan7
    HoldenMan7 Member
    WA
    VZ SS 6 SPEED MANUAL
    There shouldnt be any difference between the two, even though the S/C engine would be made a little stronger to hold up with the S/C, if both engines are driven the same and looked after they should both live a decent life...
  5. Cobez
    Cobez LS-EXUAL
    2004 S2 VY SS Ute
    True ^^^ if you are meaning the L67 Holden factory blown engine.
    If he means whacking an aftermarket blower on an ecotec, it might differ slightly. I guess it all depends on what kind of life the engine has had.
  6. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    economy should b roughly the saem youd think if they were driven fairly passivly. boot the right foot down and youd asume the S/C would start chewin the juice more than the ecotec.
