how much brake fluid??
Discussion in 'General' started by VL Berlina 5speed, Nov 22, 2008.
  1. VL Berlina 5speed
    VL Berlina 5speed Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    well this is a basic question,
    how much brake fluid is in the complete brake system on a early commodore???
    i assume the vb-vl all have the same pipes etc and contain the same volume
  2. greenacc
    greenacc Searching for the billion
    VE Berlina
    about 1 litre .... so if you buy 2 500ml bottles you should be sweet. If you are starting off empty you might want an extra bottle cos you will use a bit more to bleed the system.
  3. VL Berlina 5speed
    yer it should be completly empty,
    all calipers were off, master cylinder/booster was off
    so ruffly 1.5ltr or 3 of there 500ml pbr bottles
    cheers
  4. Farlig
    Farlig Member
    Y-Series Clubsport
    didnt think anymore than 500ml was in a brake system, same with clutch.
