The only way you will know for sure is if you get a quote from a painter. You won't get a definite price that one of your local painters will charge unless you ask them.
generally for same color resprays with no panel damage and no need to hifill i'll charge 180 a panel, for panels that require body filler and priming, the price moves to around 250 a panel, all 2k paints...also if your after color sanding of the clear. most panel shops will quote between 250 - 350 a panel regardless of repair work or preperation needed
