How much is a 304 v8?
Status
Not open for further replies.
Commodores86
South Australia
had a vk commodore
Hey, just wondering how much a vn or vp 5 litre v8 costs and how much work would i have to do to put it in a vn that used to have a v6?
Could 2 cams be able to fit into a vn or vp 5 litre v8?
Morton
For external use only
34
Fairstar the Funship
Hey, just wondering how much a vn or vp 5 litre v8 costs:
$1500 with transmission and loom and K frame, plus extra for V8 brakes and suspension.
and how much work would i have to do to put it in a vn that used to have a v6:
Give yourself a week if you know what you're doing, and a month if you have no idea.
Could 2 cams be able to fit into a vn or vp 5 litre v8:
You can put as many cams in there as you want, but they'll just bounce around and break stuff.
Ado
Are we there yet?
vsII statesman L67
Just buy one that already has one,much easier.
Commodores86
South Australia
had a vk commodore
Does anybody know if i be able to get a vn or vp with a vp for 2 and a half grand in SA? How big is the largest cam for a 5 litre v8?
Morton
34
You can't get a VN with a VP. You can only get a VP with a VP. And the only way to find out if you can get a VP for that price, is to LOOK. eBay, Carsales, trading post, actual car yards... there are a lot of ways to find out. This information doesn't just magically happen.
You'll find they're all the same size - roughly 21⅜" long, and 1⅞" in diameter at the bearings.
centy
Vp series 2
mate you are asking stupid question so YOU have to look around like morton said and in those places. You CAN"T fit extra cams to a engine, they are made as a integal part of the engine so can only me changed over for one of the right type.
A large cam (refers to valve timing and duration that valves are open) will NOT run in a standard engine. If you were to try you would have borken valve springs, rocker arms nd maybe valves hitting piston.
If you do not understand this then you are to STUPID to won a commodore go buy a ford.
Commodores86
South Australia
had a vk commodore
what's a good exhaust system to go with a 304 v8, a lukey performance exhaust or some thing else that's about 3 inch to 3.5 inch?
Which actually sounds better on a 304 v8 a 2.5 inch, a 3 inch, or 3.5 inch exhaust system? How much would it cost all up, probably around 1500?
greenfoam
101
VP Executive R-spec
Everyone has different tastes in exhaust note, some like the crispy sound of a 2.5 inch single, some like the deep 3 inch singles, some like the growl of a twin system. Price can be anywhere fom 20 bucks to 2500
Morton
34
I smell a troll.
But on the off-chance that you're just not quite all there, the best exhaust for a vn with a vp and two cams, is probably just a single 2.5".
Status
