hako
Donating Member
- Aug 1, 2004
- 8,020
- 96
- 48
- Age
- 80
- Location
- Toowoomba SE QLD
- VS11 BT1 V6
How much would it cost to replace a power steering pump on VS 96 Berlina
I’m pretty sure my power steering fluid is leaking at the pump.
I’m just wondering what I should expect the cost to be if I was to get it fixed via a mechanic, has anyone got any ideas?
Should I use a regular mechanic or steering specialists?
I thought I needed a new pump till I discovered the oil leaking from the pump was actually coming from the reservoir - it was leaking where one of the hoses joined the reservoir and running down the underside of the hose to the pump - this is not visible as it's all out of view.....so I suggest you check this first as it could save a few $$$. Good Luck.
