how much would it cost
ipsy
94 VR BERLINA
i want to know how much would it cost me to get a fuel pump seal and manifold o ring seals ,rocker cover gaskets ,power steering pump, and front an rear shocks fix how much would all this cost
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
I'm only guessing but parts only would be about $350 and labour upwards of $800 to $1000..... That's if you mean a fuel pump. Do it yourself and it only costs parts!
ephect
Donating Member
VS Acclaim V6
you can do most of this work at home, but purchase a manual and a few handy tools and you'll save 100's of $$.
fuel pump seal is simple: but u gotta drain the tank first, theres a few threads on replacing the pump, use them to get to ur pump seal. part=$10 max id say
manifold o rings: again rip the 6-8 manifold top plate bolts off, then remove the 4-6 bolts inside the plenum chamber then replace the o rings. part=$10-20 max
rocker cover gasket: remove the bolts around the rocker cover, then change gasket and retorque bolts. ( the rocker cover gaskets are reuseable but if you think its suspect change. part=$20-30 from memory
power steering pump: what replace the whole pump or ?? id say, remove belt, undo hoses, then undo bolts holding pump, replace.. part=$50-100
rear shocks: undo top bolts, jack car up, undo bottom bolts, replace.. parts=$80-200 pending brand and type of performance shocks
front shocks: there is a how-to on this forum. parts=$200-1000 again pending brand and what u want them to do, adjustable n stuff.
to get all this done as hako said, expensive!
