st3r3otyp3
Donating Member
- Feb 13, 2008
- 2,003
- 21
- 38
- Location
- WA bruz
- VX HSV VX SS
If you go to start your car one day and the key does not turn you ignition barrel is most probably stuffed, first try wriggling it and see if it turns if that does not work then try spraying CRC, WD 40, or better yet dry lube/graphite grease and try to turn it again. If this works you must renew the barrel ASAP If possible don`t turn it to the off position, grab a small wire or paper clip and then take off the plastic shroud around the ignition, now find a small hole on the side of the ignition barrel housing facing you and insert it in there and push now with the other hand try pulling out the key (while still in the ON position ) and the barrel will/should come out of the housing (attached to the key). Take the old barrel to Holden and get them to fit new slides and fiddly bits to it this should cost about $30- $40.
Now if theses tips did not work your barrel is thrashed and needs to replaced here`s a guide to help you get it out.
You will need
1. Roll of alfoil
2. A 100mm angle grinder with a cutting blade
3. full plastic face safety visor (not essential)
4. A new barrel housing part No GM 92046124 cost $100
A new barrel (blank) part No GM92048530 cost $60
Sundry ignition slides springs and fiddly bits part No GM 90052550 cost $8.00
5. A new Sheer bolt ,THEY SHOULD GIVE YOU IT FOR FREE OR AT WORST A $1.00.
Also Holden will charge you $30 if they put together the blank barrel to suit your key, but I did it my self and found it frustrating but fun.
Right familiarize yourself with the ignition It`s made up of 2 outer pieces the Upper strap that goes over the steering column and the Lower barrel housing that goes under the column that also houses the barrel (hence the name) they are connected by a bolt called a sheer bolt it`s called that because the top grip-able part of the bolt is sheered off when tightened at the factory leaving no grip-able surface to undo it (aids security).
Right`o, line the whole drivers side with alfoil (including the seat) and grab the angle grinder. Now U want to cut through the sheer bolt near the highest part of the lower housing where its attached by the bolt to the upper strap, you want to just shave the lowest part of the upper strap when you cut through it so you can use it again. You will notice that the upper strap indent`s into the lower housing like a bowl and the sheer bolt sits in this bowl so just imagine were the Angle grinder blades are going to slice when you go through. Ok mark it and cut, it should take about 5mins of hard cutting.
Once off the new housing will fit perfectly ( note the steering lock button on the housing and the hole it fits into under the coloum )
but if you can help it don`t ruin the upper strap otherwise you will need to buy another one Part No GM 92046132 cost $13 and will be a pain to fit even when using a G- clamp to hold them together while you try to attach the new sheer bolt.
because your old one has been slightly stretched to fit the coloum and is an easy glove like fit.
Get holden to help you about the best tool and method to use that tool to fit the sheer bolt as the tops are fragile and could snap half way through attaching it.
P.S I used a normal bolt with a phillips head screw driver head on it and was easy to put on, so if it happens to me or the next owner of this car again I/they don`t need to use the angle grinder to get it (the barrel) off just simply undo it. though it makes the car easier to steal though people dont need take this off to hot wire the car they only need to get this off to disable the sterring lock so they can drive it with no key and be able to steer. I personaly just rely on the deadlock function on the door ( dukes of hazard anyone ) and the Imobiliser. Plus I live In a small W.A town and keep it in a locked shed.
P.P.S I have pics ( Including exactly where to cut ) just send me a private message and I will put up associated pics for this thread for 24 -48 hrs max. as I need the space for other pics on other threads.
GOOD luck fellow commo-nuts.
You will need
1. Roll of alfoil
