How the hell can i get all the freakin coolant out!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by freefallin, Feb 11, 2013.
  1. freefallin
    freefallin Member
    UAE
    VY Berlina / VZ SS LS1
    I just drained the block by removing the knock sensors (and yeah i did poke the hole with a screw driver cz there was sludge blocking it). Waited till the last drop. Then drained the radiator.
    And at the end all i ended up getting out was 7.56 liters! And i know the engine holds 12 liters. Where the hell is the 4+ liter??
    Its becoming really frustrating!
  2. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    The heater hoses and heater core will probably hold a litre or two, maybe more..
  3. freefallin
    freefallin Member
    UAE
    how do i drain that?
  4. showbags
    showbags SENIOR EL'BAGO
    VT Calais, BMW 135 m sport
    Need to take out knock sensors to completely drain it
  5. IBLOWN
    IBLOWN Well-Known Member
    VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
    I have never drained any of my cars coolants completely, never had a single problem. What for? Just flush it with the hose until you get no more colour and put coolant in it.
  6. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    He did that.
  7. Cashman_309
    Cashman_309 Member
    VTII Calais
    If you're really OCD about it you can hookup compressed air to one of the hoses and try blast it all through, however, I have been told this can cause more damage than it fixes.
    If you have run the hose till it comes out clear, then you have done it right anyways.
  8. markbaja
    markbaja New Member
    VY Exec & SZ Territory Diesel
    I've usually drained "most" of the coolant out by taking thermostat out, then filling with water, run engine for about 5 minutes, with heater on high of course, then drop bottom hose. Repeat three or four times, usually water comes out pretty clear. Put new thermostat and gasket in. I figure the system takes 12 litres, so a 5 litre bottle 50% mix, straight into radiator, then a 1 litre bottle 50% mix in the overflow bottle. Done that to both cars on a bi annual basis, and never had a problem.
    And make sure you bleed system after changing coolant.
    Sent from my GT-I9100 using Tapatalk 2
  9. showbags
    Oops. My bad. Didn't read it properly.
  10. umair
    umair New Member
    saudi arabia
    Sold my car :(
    Never put compressed air in the system. Yea it will take all the water out, but any hard and sharp debris in the system will be forced flying out at high speeds which can break/cut the seals easily.
  11. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
  12. markbaja
    markbaja New Member
    Yes, sorry, bad explanation.
    Concentrate into radiator, top up with water, plus the water left in equals 50% mix. I think I know what I meant. :doh::doh:
