eaton v8
my little sleeper
- Jun 6, 2008
- 608
- 1
- 18
- Location
- gladstone qld
- vz 6l auto 239cam 3.9diff
so how is it done????? im sick of swearing at it and carnt figger it out
the following is when the steering column has been removed from the car follow the instructions for the lock cylinder only you DO NOT need to remove the steering column!
1. remove steering wheel
2.lower column cover
3.indicator switch mechanism
now the igniton lock cylinder
also you may need to break the slot with a screwdriver, and press th clip with a piece of hacksaw blade or paper clip or similar.:thumbsup:
it did work before i changed the barrel now it wont play ball
