How To: Change Springs/Shock
greenfoam
102
VP Executive R-spec
:bow: @ VP_Luke and :bow: @ MarzVP
What's with all the VP's :)?
cacaman
Red is Faster
Vr Acclaim
Just a question
When changing springs to make the car lower is it really necesary to change the shocks other than the fact that they might fall out if the car if raised agian?
mistaken
... pimpin it VT stylez
VT
cacaman said:
Just a question
Not if you're putting FE2 or equivalent height springs in. Anything lower and you may need to replace shocks.
However saying that - if the car is >10yrs old and still has originaly shocks, it would be worth splashing out ~$70 for a pair of new standard shockies front n back. Or a little more for performance shocks.
I'm looking at putting FE2 springs into my VT S1 soon - I'm considering replacing shocks all round (standard tho, not perfoemance shocks).
90VN55
34
stanthorpe, qld
90 VN SS 5speed, '90 VN Calais 5speed
Make sure you torque up all bolts that should be torqued and locktite all bolts that should be locktited
which bolts need locktite put on them?
Shounak
The Kicking Horse
37
VX Executive S2 + XF Panel Van Project
_A_D_A_M_ said:
what do u mean by torque up
sticky!!!!!
i always wanted to no how to do this. and what do u mean
It means tighten them to the correct tightness.. Usually done by an adjustable torque wrench..
AirStrike
91' VN SS
Only done with a torque wrench. Depending on what it is thats being tightened it will normally list either an primary torque setting (in lbs-inch, or Nm) and a secondary torque setting, or a primary torque setting then a secondary angle to which you must turn the torque wrench.
AirStrike :air:
totality
VT Berlina wagon 5.0 litre
ok i know this was done on a VN/VP setup but is the procedure the same as doing a VT?
i am planning on doing my VT front springs soon and wanted to know if i could use this same procedure for it?
VN_Luke
ƃuoɹʍ ʇsnɾ sı sıɥʇ
Mexico
Get in the ute
it's all similar..
not bolt for bolt/word for word - but if you're confident with cars and tools you'll have no issues.
F
foammedia
Guest
I changed the strut bearings and shockers in the front of my VP the other day. I didn't pull the struts off the car. I did one side at a time with the car on a jack and compressed the spring and droped the strut out under the wheel arch then replaced the shocker and put the new strut bearing in, it took me a long time about 3 hours per side but I could have done it faster if I wasn't stuffed around so much. The one thing that anoys me is that I replaced the stock strut bearing plate with nolathane ones as I couldn't get stock ones. The nolathane ones are thicker than stock so now my FE2 car sits at stocker ride height at the front, which means I'll need to get super low springs to make it back to stock FE2 height, that sucks so be prepared for that if your strut bearings need replacing and you are going with nolathane ones
90VN55
34
stanthorpe, qld
VP_Luke said:
Things you will need:
- Socket set
- Spanners
- Spring Compressors
- Big heavy hammer
- Rattle gun
- Some way to lift the front of the car up
- Random items you could find handy.
how much are spring compressors?
and where do you buy them from?
