VT-565
while this seems like a good idea, dont do it. if you are going to flush any sort of oil through your engine, make sure it is the same oil you have been running.Shounak said:Look if you want to do a thorough job, after the oil has drained. Fill her up with some cheapy oil and run it for a little while and redrain the thing..
Let me tell you guys that most oils are different and so are the additives in them. detergents and stuff in there to clean and help lubricate your engine....some of these additives react with each other if theyre not compatable and can in some cases create mild acids. yes, acids. not the first thing you would want to pour into your engine.
Same goes for the engine flush sh*t too, you guys know that kerosine and diesel are actually cutting compunds? that means they are abrasive.....would you run an abrasive through your engine? a handful of sand maybe? didn't think so.
So, leave the magic engine flushes alone and stick with some of the same oil you are running to do the job. after all, you will never stop carbon deposits building up in your engine...thats what rebuilds are for.....happy motoring:thumbsup:
