How to change the transmission oil and filter?
dallascowboy
VE SS
I'm confused as the how to correctly check fluid level on my ve SS 6 speed auto, trans specialist bloke said to me undo the drain plug on the bottom sump and it should trickle out of full but Wont it all drain out if I remove the plug ? Do I just unscrew the drain plug a little bit or completely remove it ?
you may already have your answer but ill let ya know too as ive done it like 5 times in the past few months to get the level right on the wifes 09 ssv wagon
backed it up on ramps then jacked the front of the car up so they trans was level..(used a magnetic level and stuck it to the underside of the trans)
the guy from holden said to run the car round the block then put it up on the jack stands, once on the jack stands keep it running until your trans sump temp gets to 45-50degC (the right temp for checking apparently, well thats what the bloke from holden said to do anyways) and keep it running while your checking
once at 45-50degC undo the sump plug .....the oil should be just slowly coming out (not full on like ya dumping oil out like ya engine oil)
If the oil is coming out real fast and heaps of it ya have too much oil and ya need to let it come out until that slow drizzle happens.
if no oil comes out you need to put more in...this is done by the fill hole on the top edge on the drivers side (its shown in one of the picks a few comments up) or you could use a hose thats smaller than the sump hole and pump it up into the sump plug untill it starts drizzling out again....ive seen some cars done this way but i did the fill hole at the top drivers side just to go by the book.
in either case once its at that drizzling out point put the sump plug back in and ya done!!!!
I think this is one of the worst designs ever for just "checking" ya oil level but what ever...makes it harder so more people will just pay holden to do it
ive done this like 5 times in the past few months cause i checked it at different temps, lower and higher and the 50degC mark has given me the best result for smooth changes
the reason all the oil doesnt come out is the pan has a raised "tube" above the sump plug that raises the level above the sump plug hole...you can see in my pic from when i took it off to change the oil and filter
anyways hope this helps....i know i was baffled at how to do it when i first had a crack cause of how stupid the design is. Just put a lockable dipstick in the engine bay!!!!!!!!!
dallascowboy
VE SS
To check the trans oil temp put the car in "engineering mode"
push the left scroll wheel into the steer wheel, hold it there and turn the ignition on, then let go of the scroll wheel...you should get a list of things on your center screen on your dash cluster...scroll down to trans temp.
Jackv8
39
Gold Coast
2012 SS-V II
dallascowboy;2741041[/QUOTE said:
Excellent post Dallas spot on ( should make a thread sticky post with this! I went down to Holden after work today and spoke to a service bloke he explained the exact same thing & method :) i must say the gear change is much smoother now my fluid wasn't that bad as its only a few yes old the gearbox..
I like your idea backing up on ramps then jacking the front I had to use 4 stands was a bitch getting level...
dallascowboy
VE SS
Good that the guy at holden said the same thing....at least i was on the right track!
Yeah the ramps and the stands make it easier....would be soooooo much easier with a hoist!
Jackv8
39
Gold Coast
2012 SS-V II
Oh yeah same needs a hoist :) yeah mate spot on with the fluid check :)
tandawwg
VE Calais V
How much fluid did you end up replacing? I have a 09 Calais V with the 6-Speed 6L50 and when I dropped the pan it dropped out 5L
redvxr8clubby
Sunshine Coast QLD
VX Clubsport R8 & VE SS
Seems easy and will do in the next day or so. Thanks for your help, I really appreciate it.
Joey, I think the 4 speed auto would be the same as older Commodores, I have done VS Exec (1997) and also VX Calais. Easy enough to do, but messy trying to balance the trans pad full of fluid as you remove all the bolts and lower the pan.
Dynamic Dazz
54
Australia
Ve Wagon
Wow just found this thread......I love working on my car but always thought transmissions oil and filter was a specialist job.....cant believe how simple it SEEMS......certainly going to give it a go myself.....my mechanic quoted $280
Dazz
Blackout
2010 VE SV6
Yep, I can confirm this.
(I Just completed the Deep Pan, Wide Mouth Filter mod on mine today).
image.php
Just in case this helps anyone, the filler plug is located on the Drivers side of the transmission, just above around the middle of the Pan.
image.php
I'm interested in this deep pan & wide mouth filter mod. Can this be done for the V6 6 speed auto?
