Nut Kracker
Donating Member
- Oct 18, 2012
- 4,760
- 151
- 63
- Age
- 64
- Location
- Echuca Vic.
- VT SS 304ci (195i)
Just thought I would explain how to convert known Wattage to Amps and known Amps to Wattage.
This is very handy when you know the Wattage of a component and need to know the Amperage for the correct fuse or wiring to use,
or you know the Amperage, and need to know the Wattage.
It's very simple and here are the equations.
To work out the amperage.........
Watts (divided by) Volts = Amperage.
Example - 120 watts (divided by) 12 Volts = 10 Amps.
To work out Watts........
Amperage x Volts = Watts.
Example - 10 Amps x 12 Volts = 120 Watts.
Just remember that just because a component/s is drawing say 60 watts, don't just use a 5 amp fuse.
This will be right on the limit of the power consumption and will not allow for small current spikes or slight over loads in the system.
If you use a too higher amp fuse, it will take longer to blow if there is a problem and could cause serious damage to the component and or the electrical system.
Do not use foil or any other things to relace a fuse as these foriegn objects will not blow as a fuse is designed to.
