how to divert power steering fluid
91luxy
brisbane
vs v6 commodore&vs v6 91 hilux 4x4
I have put a vs ecotech into my 4wd and havent got the power steering box for my hilux yet .
How to run the car without power steering hoses running to the power steering box . Can i just create a loop between the 2 hoses or block them off without damaging the pump .
91luxy
brisbane
if i block it of it would be the same as not turning the wheel wouldnt it
woteva
NEED 4 SPEED
Adelaide S.A.
Don't block it, you will have to loop it. The fittings/hoses are different sizes so it won't be easy. Might be able to cut the ends off a couple of old hoses and put a joiner/adapter in the middle.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
or get a short belt and a ribbed ecotec idler pulley for the tensioner :D
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
Wouldnt blocking it of just leave the pump idling? Like no issue there, just the same if it were running in a commodore and not turning the wheel.
Guzzoline addict
vr v6
I dont think you should loop it because you'll be running a high pressure hose into a low pressure reservior. Also blocking the high pressure hose might wreck the pump.You can use a ecotec ilder pulley on a pre ecotec motor to get rid of the pump http://www.osp.metrohosting.info/v6ps.html but i am not sure about the ecotec.
91luxy
brisbane
ha thanks Guzzoline addict and everyone.
i ended up getting the hose fixed for the power steering so its now ready 2 start
but its not starting. fuel pump is working(good fuel pressure, every thing is hooked up, turning over fine, no leaks
how do i check the spark and injectors for power or something that is stoping her going the car is a v6 ecotec auto conversion in hilux 4x4
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
do you have a tune with no security or a bcm simulator if not it wont start
