yes i got it of ebay no vats no bcm
9 91luxy New Member Joined Nov 19, 2010 Messages 107 Reaction score 0 Points 0 Location brisbane Members Ride vs v6 commodore&vs v6 91 hilux 4x4 Feb 26, 2011 #11 yes i got it of ebay no vats no bcm
delcowizzid on holiday Joined Jul 8, 2008 Messages 6,988 Reaction score 445 Points 83 Location NZ Members Ride в∞ѕтεכ √& Feb 26, 2011 #12 do you have constant power to A8 B8 at the ecu and switched 12 volts to A4 and E9 and an ignition power feed to the efi relay to turn on the dfi and injectors
9 91luxy New Member Joined Nov 19, 2010 Messages 107 Reaction score 0 Points 0 Location brisbane Members Ride vs v6 commodore&vs v6 91 hilux 4x4 Feb 26, 2011 #13 yes i think so should i go down and check that i have a volt meter but dont know how to use it realy
delcowizzid on holiday Joined Jul 8, 2008 Messages 6,988 Reaction score 445 Points 83 Location NZ Members Ride в∞ѕтεכ √& Feb 26, 2011 #14 set on 20 volts setting hook one probe to earth on the body somewhere and use the other probe in the wiring plugs for the ecu
9 91luxy New Member Joined Nov 19, 2010 Messages 107 Reaction score 0 Points 0 Location brisbane Members Ride vs v6 commodore&vs v6 91 hilux 4x4 Feb 26, 2011 #15 allright ill do it now back in 5
9 91luxy New Member Joined Nov 19, 2010 Messages 107 Reaction score 0 Points 0 Location brisbane Members Ride vs v6 commodore&vs v6 91 hilux 4x4 Feb 26, 2011 #16 i have no power to e9 A8 has 12.6v B8 has 12.6v A4 has 11.15v
delcowizzid on holiday Joined Jul 8, 2008 Messages 6,988 Reaction score 445 Points 83 Location NZ Members Ride в∞ѕтεכ √& Feb 26, 2011 #17 E9 and A4 should be pink just join them together
9 91luxy New Member Joined Nov 19, 2010 Messages 107 Reaction score 0 Points 0 Location brisbane Members Ride vs v6 commodore&vs v6 91 hilux 4x4 Feb 26, 2011 #18 yer e9 is pink ill cross them and see if it fires
delcowizzid on holiday Joined Jul 8, 2008 Messages 6,988 Reaction score 445 Points 83 Location NZ Members Ride в∞ѕтεכ √& Feb 26, 2011 #19 after that check power on the injector plugs with ignition on in the same way you just tested the ecu plugs and the red wire at the dfi plug
9 91luxy New Member Joined Nov 19, 2010 Messages 107 Reaction score 0 Points 0 Location brisbane Members Ride vs v6 commodore&vs v6 91 hilux 4x4 Feb 26, 2011 #20 when i cross the two the volts go from 11.4v to .4v is this normal
