It's a shame none of the pictures show up, and I at least, don't even get the links as described by kopper69.
However, I have found a way to retrieve the original images via the Internet Archive. See here :
https://web.archive.org/web/20060904113331/http://www.members.optusnet.com.au/scfaq/window/?N=A
When I have the time, I'll have to check if this is the problem with my own VS.
Finally, I must take exception to two little things :
- The claim that silicone promotes rust. That is only with the acetic-cure type, not the neutral-cure type.
- The method described for removing the rear seat bottom. The official method is to push the lower front edge of the seat backward and upward on each side, about a foot in from the door, so as to disengage the two retaining clips. Then the whole thing just lifts out from the front. (Note, from VT onward, a completely different retention system and removal method applies.)
Joe.
