[VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
Discussion in 'Holden Commodore How-To's' started by ephect, Apr 19, 2009.
  1. chris 2012
    chris 2012 New Member
    hervey bay
    vs ute
    I recently had 3 lights come on when driving around one was fuel , overspeed and the question mark next to it and when I checked the code 12 and 76 came up , looked at the gregorys manual and had a few things which sound interesting , ive never had an oxygen sensor fail in 13 years of owning a v6 commodore , I have changed the instrument cluster from basic vs ute ( no tacho ) to a berlina cluster , swapped the cluster over to test and no lights have come up but my economy goes from 9 to 10 around town to 15 or 17 , so should I try to find which sensor has failed or just get 2 new ones ???
    the spark plugs have only done 13,000kms and should do 25 to 30,000 and ive never had a bad spark plug , I might change them first but I think its more likely to be a oxygen sensor as the utes 13 years old
    thanks chris
  2. ephect
    ephect Donating Member
    VS Acclaim V6
    Sensors fail, that's a given. Sometimes U don't get a code. After 13 years its worth changing ur o2 sensors anyway.
    Are U measuring ur consumption via the pump or the trip meter? If lights and codes have only been logged since the cluster change, is it possible to swap back for a tank to check?
  3. chris 2012
    hervey bay
    vs ute
    ive owned about 7 commodores in that time and never even had an engine or gearbox failure I think there a very tough car the commodore there not perfect but no car is , measuring fuel consumption via tri metre yes , swapped clusters over now its got the berlina v6 one in and code still comes up , the fuel economy went from 9 to 10 and now uses 15 to 17 and I have noticed it will use 4.0 when idling along ( up from 3.6 litres before ) but as soon as you start accelerating it goes to 17 or 22 litres per 100kms on the instant readout , what type of oxygen sensors would you recommend ? got some prices and around 80 each from supercheap and there bosch , read online about the cheap ones for 30 or so but there cheap for a reason did think about swapping each one over and seeing if I could find which one has failed but I guess there is an easier way to find out ?
    thanks chris
  4. chris 2012
    hervey bay
    vs ute
    just wondering if I should buy on ebay or go to supercheap and get them ?? haven't really bought much online and not sure which seller is better to deal with , read that some sell 2 for $89 plus 8 postage and bosch , its a huge price gap between the shops and online , also with the fault codes Code 76 - Air/Fuel ratio variation between left and right banks Code 78 - Air/Fuel ratio variation between left and right banks , im getting 76 does that mean the right or left hand side sensor has failed
    thanks chris
  5. VPRob
    VPRob Active Member
    nowra, NSW
    VP executive sedan V6
    Hi ephect
    digging up this thread because I am having trouble getting a 4 wire O2 sensor working in my VP (V6). Actually running a VR motor on the VP ECU with the original memcal. Have used a VR O2 sensor and installed it in the VR position. You can read my thread here: "O2 sensor info sought" in the VN VP section.
    The specific question I have is where did you earth the 50cm wire to for your fix? Is it in the cabin or in the engine bay? I figure there's not much point in doing the earth fix and not using a good new earth attachment point.
    I currently have the earth return for the signal hooked up to the dedicated black wire in the harness and the heater earth secured to a bracket on the firewall so I have them separated. The mechanic shop that did the original install, including the power take-out for the heater circuit from the injector power cable, just ran both earths to a bolt on the tranny body very close to the O2 sensor at the bottom of the Y pipe. I tidied up their work and thought that running the signal earth back to the dedicated wire in the harness was going to be a sure fire fix but I still get a code 13 once the motor gets up to temp.
    Anyway I am thinking that your earth fix can't hurt and may sort out my problem. If not I will move the sensor back up to the top of the Y pipe which is the VP position.
    Can't do anything for a week as my VP is away with my daughter in Sydney till next weekend but researching in the meantime
  6. VSJas
    VSJas New Member
    VS V6
    Thanks!!
    I recently did this fix, (still have not replaced the sensors though) I just used a wire brush and scratched the paint off the outside of the glove box surround where a screw is attached, seems to be working well I no longer get fault 13 and I've nearly halved my consumption (ball park estimate). My ute usually only barely gets me through the week on a tank without running aircon. This week I've had aircon on every drive and have only used a little over half a tank, with around same as usual K's driven. It used to rev inconsistently (high-low), used to SLAM into drive, and inconsistent gear changes (was a real PIG to drive) now as time passes after the fix everything seems to be settling out!! LOVE my ute again!!
    EDIT:
    Although it seems good, is my earth point good enough??
  7. Matt02SS
    Matt02SS Donating Member
    Port Pirie, SA
    VY SS + VY exec + Vs wagon
    Will be doing this in the next couple of days, but just to be clear, once this is done the pink wire does not need to be cut does it? Also, if i havent got the codes listed is it something else or it still possible that this is the fault without the codes being up? Thanks in advance.
  8. ephect
    VS Acclaim V6
    Normally u'll have the codes logged to indicate the problem, in saying that I don't believe doing this mod with hurt to try..
    If U go ahead with this, U don't need to cut the pink wire, as it fixes the earth problem at the ecu.
  9. Matt02SS
    Port Pirie, SA
    Thanks heaps mate, appreciate it.
  10. KrisG
    KrisG New Member
    '96 VSII Berlina
    Just a bit of feedback. My VS started idling very roughly, almost wanting to stall some times, only on idle. It was getting code 76 and was also taking a lot longer to start. Fuel consumption has always been okay but never great.
    I tinkered with a lot of different things with no improvement, so I thought I'd give this a crack.
    After re-earthing at the ECU, the idle was back to normal, the fuel consumption was considerably lower, it starts up almost immediately, and overall driving is a bit smoother too.
    I didn't think it'll make such a big difference, but for a simple little fix, it was well worth it. I definitely recommend doing this. Thank you ephect for this one.
    I had replaced my o2 sensors with genuine replacements about a year ago, so I didn't bother doing them again after this mod, and they seem to be fine.
  11. ephect
    VS Acclaim V6
    Cheers for the feedback, glad its sorted ur issues and brought ur fuel consumption back down :)
  12. -=ApheX=-
    -=ApheX=- Member
    Ya mums house!!!
    VS 3.8l Exec
    Tip of the hat to you Ephect! I've done exactly as you've described and am now getting terrific fuel economy! Last long trip I made in my 95 series 1 VS vacationer V6, the fuel in the tank from full to roughly 30kms left in tank, I achieved 680kms highway driving compared to the 460ish I was getting... For a 20year old car that's just too good!
    BTW I know this maybe an old thread and be criticized for thread digging but this info is very relevant and highly recommend any able person to consider this earth fix.
  13. ephect
    VS Acclaim V6
    Hey Aphex, glad this threads still useful and being used. Simple mod for a great result.
    Did u end up sorting out ur noise/hum?
  14. -=ApheX=-
    -=ApheX=- Member
    Ya mums house!!!
    VS 3.8l Exec
    No mate I haven't, and getting a video with audio of this happening is proving a little difficult. I take the serpentine belt off, tick her over and wait recording away hoping that it won't take long. So yeah, to no avail i'm afraid. I'm looking forward to that one suggestion or comment that'll blow my world and sort it out for me but it is what it is!
    Anyways Thanks again! Fantastic How-to! I've recommended friends, family and my partner whom all own VS commodores, to get amoungst it, get there hands dirty and let that wave of prideful completion take over!
  15. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Hi i have error 13 on my VR. I had the issue then fitted a new sensor yet the problem remains. What could it be since the fix is not for VRs?
  16. ephect
    VS Acclaim V6
    Hey mate, I don't believe this affects the vr, only the Ecotech vs. might be worth a shot but not confident it'll did your fault
  17. losh1971
    North Tas
    VR Ute V6
    Gonna replace the plug and see what happens. Also bought cable to replace the signal wire and ground if the plug swap doesn't sort things.
